Results 1 to 7 of 7
Thread: LED Pool Light Options
    Nov 2011
    Jacksonville, FL
    62
    Hi. I have a Hayward LED lights. These are the older ColorLogic 2.0 version.
    With a remote I can do a color show with the 2 lights in the circuit.
    Both have a failed and both were previously replaced once under warranty.
    So definitively not the most reliable system.
    Interested in alternatives that have worked well for others
    I would like to stick with LED, remote to turn on/off, and the ability to have some type of color show.
    I found several ugly reviews regarding 4.0 ColorLogic system which makes me a bit nervous replacing them with these, although that appears to be simplest option.
    Any one have good success with 4.0 system??
    Thanks
    34x17, IG gunite pool, Cathedral shape, Hayward Pro-Logic automation, 40,000 gal T-cell 15, Hayward EcoStar VFD, Hayward Star-Clear Plus C1200 Cartridge Filter, Hayward ColorLogic LED lights x 2
    Jan 2016
    Oklahoma
    69
    Re: LED Pool Light Options
    I put in some color splash xg lights. I spoke with one of their tech guys and they appear to be serviceable. I've only had them about 6 weeks though so no long term experience. No remote. Cycle the light switch to change between colors/shows. So far we like them.
    Vinyl, 20' X 44' in-ground, 35,000 gallons, Inteliflo VS 3HP, Triton TR-100 w/ activate, MasterTemp 400,000K LP, Dolphin Supreme M500, Hydramatic Hydraulic Auto Cover, TF-100 Test Kit.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,384
    I love the color logic.. UL listed for most common niches..
    I do recall problems with the 110v a few seasons ago.. The 12v have been rock solid.
    Very cool simple upgrade.
    Ray
    Jan 2016
    Oklahoma
    69
    I hope they got the 110v worked out. I just put in three of them.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Funny (because I should know) but I don't know if we have the 110V or 12V, but they are the ColorLogic 4.0's. I've had two of them for 4 years in our pools with zero issues. They work great for me.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Nov 2011
    Jacksonville, FL
    62
    Good to know about 12V version.
    I know I had the 110V so maybe getting an transformer installed to flip to low voltage would increase life span.
    Apr 2013
    Sacramento, CA
    2,769
    All the major manufactures had problems with their lights when they switched to LEDs.
    Based on what we see now on TFP there is not much difference between any of the LEDs from any of the major manufacturers.
    Amazon reviews can be very misleading. The vast majority of folks who buy and install never write a review. So those can be very skewed.
    The major pool equipment manufacturers have two very strong incentives to get it right, retention of their distribution network and keeping the cost of warranty claims under control. So when they have a problem with a product they tend to fix it quickly.
    That is also why they have partially excluded DYI installs from their warranties. Excluding the DYIs cuts down on the handholding time and paying for repairs caused by faulty installation.
    As time goes on I would expect LEDs from the majors to last longer and have less problems.
    Finally, you just can't install a transformer you buy at home depot and magically increase the lifespan of your lights. First any transformer must be pool rated and listed by UL for pool use. Second, the bulbs must be low voltage and many times the fixture must also be up dated.
