My SWG Cell shows 0 volts 5.0A
Simmer
0
Aug 25, 2016
42
FLORIDA KEYS
What does 0 volts mean? Its not producing chlorine? It was 17.9 volts two days ago.
I suspect my FC is really high since i get a washout on the Taylor test. It only goes up to 10ppm, and it keeps showing 0 FC. I ordered the TFPC version, so I will know more when I get it.
no error messages are present. the purifier was 10% lower than normal, and the unit was not in boost mode.
Where does the put the purifier % at then? The purifier % is what activates the cell. A 50% setting here means that the system will produce chlorine for 50% of the time that is running and then not produce chlorine for 50% of the time. If doing a test during the idle period you may see a 0 volt, 5.0 amp reading.
