Results 1 to 8 of 8
Thread: Leak Under Pump When Pump Turned Off
    Oct 2014
    Braintree, MA
    52
    When I turn off my pump (Waterway Hi Flo) there appears to be some water seeping out from somewhere near the filter and between it and the pump on the ground level. Can really figure out where it's coming from. Read that it could be a seal in the pump--does that seem right?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Leak Under Pump When Pump Turned Off
    Does it only leak when it is off? Seems like some more sleuthing is in order - you've got to look closely and figure out where it's coming from before a fix can be suggested. Various seals in the pump could leak...but so can lots of other things!
    mas985's Avatar
    Pleasanton, CA
    11,737
    That doesn't sound like a seal. If it were the seal, there would be water between the motor and the pump on the ground. A leak near the filter could mean a multi-port valve leak. What kind of filter do you have? Is this an AG pool?
    Mark
    Oct 2014
    Braintree, MA
    52
    Seems like more of a leak when turned off. But when I have filter at low speed I notice that there are three leaks---one from the ground level of each side of the filter. And the other leak is coming from right underneath the basket on the pump. Filter is a Hayward and it is an above ground pool. Have a few pictures not sure if these help.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The leaks in the picture could be the seal but they could also be the o-ring that sits between the pump basket and volute.
    Mark
    Oct 2014
    Braintree, MA
    52
    Quote Originally Posted by mas985 View Post
    thanks mas.
    could you tell me --- do you know exactly what part that is on this diagram? would it be #8?
    Waterway Hi-Flo Above Ground Pump Parts - INYOPools.com
    and then i'm assuming i should hit the seal while i'm there
    do you know which one that is on this diagram? thanks!
    https://www.poolpartsonline.com/p-84...ter-parts.aspx
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, it would be number 8. The seal is part of the pump and in the first diagram # 14 but if you get a GoKit it will have all the seals and gaskets.
    As for the filter, the spider gasket is 01E but there are other o-rings and gaskets that could be leaking as well.
    Mark
    Oct 2014
    Braintree, MA
    52
    Thanks so much. So i'm guessing on the filter that I need to just take it all apart and look for any worn out stuff?
