Thread: How to clean Taylor salt test cylinder?
    Ronald U.'s Avatar
    May 2015
    Pearland, Texas (near Houston)
    88
    I just purchased a Taylor K-1766 Sodium chloride test kit. I notice afterwards that there is a creamy bathtub ring left inside the cylinder that doesn't wash away easily with water. Use weak bleach to clean? I'm assuming sticking my finger in and wiping it out is not the smartest way. Thanks.
    In-ground gunnite, 24k gal., Hayward DE filter, bleach, borate, Hayward Tiger Shark robotic cleaner, 75% full sun
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: How to clean Taylor salt test cylinder?
    When I feel bold and need to add some muriatic acid to my pool, I first pour a smidgeon into my test tubes to clean them out (tossing the ma into the pool after a few seconds and rinsing well in the pool water). Works well for me <climbs on her horse and rides off in to the sunset>
    but...
    you might want to try some vinegar and rinse it out in the sink and wipe dry with a paper towel. yeah, that'll work too
    JoyfulNoise's Avatar
    May 2015
    13,231
    It's silver chloride. Just rinse it out good with water and use some dish detergent. Rinse again very well to remove any excess detergent and then wipe out the inside of the tube with a paper towel.
    It's "sticks" because it's very fine particulates that are statically attracted to the plastic surface of the tube. Physical wiping works the best. Bleach won't work and messing with acid is not advised.
    If the above cleaning method does not work, one can use a diluted ammonia solution (straight ammonia cleaner, no additives if possible) to clean out the cylinder. Silver chloride dissolves in ammonia solutions.
    Matt
