Thread: Hurricane coming - run the pump or not
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I live in NC and now they are saying Hermine is coming through on Friday and Saturday with "tremendous amount of rain." I'm going to bring the Chlorine up to about 10 ppm by Friday morning. Wondering if, after it is mixed, should I run the pump during the downpour or leave it off. I have a drain like in a bathtub that will drain water out when it gets too high. Thanks!
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Hurricane coming - run the pump or not
    I would raise FC up to shock level for your cya, FC/CYA Chart. I wouldn't run the pump when you aren't there if there is a chance of a bunch of debris getting in the pool and clogging the skimmers.
