Results 1 to 8 of 8
Thread: Is Hayward Aquarite AQR-15 lifetime equivalent to Pentair IC40
    Jul 2016
    Austin, TX
    348
    I'm doing a cost comparison between Pentair and Hayward SWGs. The biggest Hayward SWG is rated at 40,000 gallons...does this mean it compares to the Pentair IC40 in terms of total chlorine generation capability? I would chose the IC60 over the IC40; however, just trying to compare total cost of ownership.
    JoyfulNoise's Avatar
    May 2015
    13,253
    Re: Is Hayward Aquarite AQR-15 lifetime equivalent to Pentair IC40
    Largest source of info on SWG's is here (it was compiled using independent data and so this is truly an apples-to-apples comparison without a lot of company-specific influence) -
    Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    The Mother-of-All-SWGs (MOAS) would be the CircuPool RJ-60 Plus which weighs in at a whopping 3.10lbs/day of chlorine gas
    Matt
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Foosman,
    Please keep in mind that without a Pentair Automation system, the IC40, or IC60, can only be controlled in 20% increments. Not something that you can't work around, but something you need to know up-front.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Also be sure to look at cell replacement costs.
    chiefwej
    Jul 2016
    Austin, TX
    348
    I just laughed really hard at the MOAS acronym...that's good!!! Thanks for the link, it looks like they both put out 1.4lb/day, but no indication of how many days they are able to produce...hmm.
    May 2015
    13,253
    Pentair quotes 10,000 hour operational life (your mileage may vary) and I think Hayward quotes less than that (maybe their realists?).
    Matt
    JoshU's Avatar
    New Orleans, LA
    543
    The Pentair IC60 cell has a pretty high replacement cost as compared to other units on the market of comparable size and spec.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Jan 2015
    Anthem, AZ
    188
    i wish things like this were stickied more. searching for the salt output and other great posts like the run time generator would be excellent sticky threads.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
