Results 1 to 17 of 17
Thread: CSI Pool Math
    May 2015
    Fullerton, CA
    636
    CSI Pool Math
    Okay perhaps it's been too many years since college, and I was bad in math anyhow. But this whole -0.6 or .06 is confusing to follow which direction it going. So I made this chart which I assume is correct so I can easily see which direction I am heading. I always associate the number on the right of the decimal point to be negative. So hopefully this is correct, and the bold values are the outer limits of the range, the underlined numbers are the range I want to target.
    1.1, 1.0, 0.9, 0.8, .07, 0.6, 0.5, 0.4, 0.3, 0.2, 0.1, 0, -0.1, -0.2, -0.3, -0.4, -0.5, -0.6, -0.7, -0.8, -0.9,-0.10, -0.11
    So if I get a value of -0.18, where is that go on the chart? Between -0.1 and -0.2? Or between -0.17 and -0.19?
    Perhaps this confusion is from my recent experience sniffing too much muriatic acid, lol.
    thanks
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Jun 2015
    Glendale, AZ
    156
    Re: CSI Pool Math
    Quote Originally Posted by Titan7 View Post
    Looks about right, you can play with the numbers to see what you can tweak, to stay in that 0 to -.3 range
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    38,516
    Re: CSI Pool Math
    That is a backward number line and the number to the right of the decimal point is not "negative" as you say it is a fraction of the whole and your right 2 most numbers are wrong.
    The bold is right and generally the underline range is correct.
    Number lines typically have negative starting on the left and numbers increase to the right.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: CSI Pool Math
    Exactly, you want to be at -0.3 and let the CSI drift up to 0, then tweak it back down to -0.3.
    May 2015
    Fullerton, CA
    636
    Re: CSI Pool Math
    thanks, but is -0.18 fall in the 0 to -0.3?
    Sep 2013
    Connecticut
    728
    Re: CSI Pool Math
    Think of it this way -- give your numbers the same number of digits after the decimal point (extend out with zeroes, which doesn't change the value of the number), and it will be easier to see. For example, compare -0.18 to -0.30. You should essentially be comparing 18 to 30, not comparing 18 to 3. So, yes, -0.18 is in between 0 to -0.3
    As jblizzle pointed out, your number line is backward from how positive and negative numbers are conventionally represented. More importantly, the right two numbers are wrong. It would go:
    -0.6 -0.7 -0.8 -0.9 -1.0 -1.1
    Does that make sense, or is it still fuzzy?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    May 2015
    Fullerton, CA
    636
    Re: CSI Pool Math
    Got it, and thank you, that is easier.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,280
    Re: CSI Pool Math
    It will help if you turn your numbers around:
    (lowest number) -0.30, -0.20, -0.10, 0.00, 0.10, 0.20, 0.30 (highest number)
    -0.18 is higher than -0.20 and lower than -0.10, so yes, you're on track and your result is in the target range of -0.30 to 0.00
    The pattern near your result from lower to higher number is...
    -0.22, -0.20, -0.18, -0.16, -0.14, etc.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    May 2015
    Fullerton, CA
    636
    Re: CSI Pool Math
    thanks, been playing with pool math, starting to make sense. I am currently at CSI = -0.47. I am trying to drop TA so I have been adding acid to a 7.2 PH and letting it drift back up. with all my other numbers remaining, once PH hits 7.4 my CSI =-0.28 which is in the 0 to -0.3 target range. Bdavis and others have told me I will drop out of range on CSI for a short time in order to bring TA numbers down.
    Thanks again for everybody's help.
    DFW, TX
    24,513
    Re: CSI Pool Math
    -0.47 for a bit is fine. It will also help dissolve your white line on the tile.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: CSI Pool Math
    Thank to you for this, I've been pondering the same question once or twice.
    May 2015
    Fullerton, CA
    636
    Re: CSI Pool Math
    Quote Originally Posted by PAGirl View Post
    I am glad there is somebody else out there, I was starting to think i was really dumb!
    With a TA of 80 my csi does the following at different PH levels. Looks like 7.4 to 7.7 is in the perfect range.
    7.2 ph = -0.47
    7.4 ph = -0.28
    7.5 ph = -0.19
    7.7 ph = 0
    7.8 ph= 0.09
    Tested ta again today, still at 80ppm.
    Last CSI pool math question. Whats up with the Goal number? I plug in numbers to get to 0 and the goal number shows -0.49 , it never seems to change, does it work?
    DFW, TX
    24,513
    Re: CSI Pool Math
    Looking good. Welcome to TFP advanced arithmetic!
    Jun 2015
    Glendale, AZ
    156
    Re: CSI Pool Math
    7.2 ph = -0.47
    7.4 ph = -0.28
    7.5 ph = -0.19
    7.7 ph = 0
    7.8 ph= 0.09
    That works but remember when something like your CH goes up or the water temp changes you have to tweak things....the 0 to -.3 is not set in concrete, you just have to be aware of what is changing and how fast it changes so you can adjust.
    and yes the CSI works well.
    May 2015
    Fullerton, CA
    636
    Re: CSI Pool Math
    Thx, i have spent several hours messing with pool math and that really helps to understand the relationship between everything.
    You are correct at a ta of 80 i can make everying perfect with a CH of 275, as that goes up a TA of 60-70 gives me more range.
    So how many times can i safely drop ph to 7.2 which puts csi out of the range in order to drop TA?
    DFW, TX
    24,513
    Re: CSI Pool Math
    Lots of times because -0.47 is still in the safe range of -0.6 to +0.6. It is just a little better to keep it -0.3 to 0 for situations like yours, and mien, where scaling is more likely.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: CSI Pool Math
    -0.3 is the same as -0.30 so -0.18 comes before -0.30 (-0.3). 3 dimes is the same as 30 pennies. I teach my students to think of decimals as money. You just add the - sign to it on a number line.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
