Results 1 to 9 of 9
Thread: Best Sanitation Option for Weekend Home?
    Aug 2016
    Seaside Heights, NJ
    2
    Hello! I am installing an AGP at a second home, possibly a 10x18 Aquasport 52 semi buried. I need a sanitation system that can be unattended every Monday through Friday afternoon. Pool store is pushing a Frog, which I know to be a total waste of money. I'd love to avoid the cost of a SWG. Could I get away with an inline chlorinator even though I know about the undesirable CYA levels it will produce? Other suggestions for pool maintenance for a weekend home? Thank you!
    38,301
    Re: Best Sanitation Option for Weekend Home?
    Welcome to TFP!!!
    I came in to recommend a SWG ... then read the post
    Given the location with rain and short season, you might be able to get away with using trichlor tablets. Just test every weekend to keep an eye on the CYA.
    The other option is a liquid chlorine dosing system, that cost is probably between the chlorinator and SWG.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Will the pool be covered during the week?
    I'd go for the SWG myself... but since you'd like to avoid that the pucks will have to be it- with the full knowledge that your CYA will eventually get unmanageable and require draining and refilling somewhat. In your area that might not be so hard to do since you do close pools down. Perhaps allowing the pool to collect rain water at times?
    You're right to avoid that darn Frog...bad news all around. Ugh.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Suck it up and go with the SWG. The overall cost will be the same over the course of a few years and it is the perfect answer for your needs.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2012
    Montville NJ
    545
    When I go on a weeks vacation, I raise my pool to SLAM levels, add a puck in a floater, and leave to solar cover on. That holds my pool for a week. When I come home, the pool CL is still acceptable (and there is usually still a half a puck left).
    You MAY be able to get away with raising your CL level every weekend before you leave, but you are going to go through bleach, and you may cause premature bleaching of your liner. If you downt want a SWG, then I would say an automatic liquid chlorine feeder.
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    A Stenner pump dispensing liquid chlorine could be a viable option for you.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    You might be able to do pucks if you plan to dump quite a bit of water each year when you winterize. Living it NJ, that could be a possibility.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree with the others, first choice would be SWG, second choice would be testing and adjusting your target FC for your ever changing CYA each weekend.
    p.s. as to cost with a small pool like that you could get away with something like the dip in Saltron Retro for about $200 (plus a couple of sacks of salt)
    Aug 2016
    Seaside Heights, NJ
    2
    Thank you everyone for the advice! Looks like SWG is the consensus, haha. I appreciate the Saltron recommendation. Any other great "bang for my buck" SWG units for a smaller pool like this?
