Results 1 to 18 of 18
Thread: Aquapure 1400 General Fault 121
    Dec 2015
    Montverde/Florida
    24
    My Aquapure 1400 system is displaying a General Fault message with error code of 121. A week ago, it showed error message 120. But after I cleaned the cell, the message went away. With the power cable disconnected from the cell I measured 16.2 volts DC. I suspected that I might have to replace the back circuit board. I would really appreciate any observation and comment on this situation. Thanks.
    Re: Aquapure 1400 General Fault 121
    Typically a cell problem. Get the salt up to about 3400, check the power cord connections and check the cell for scaling.
    How old is the cell?
    Support the site
    Dec 2015
    Montverde/Florida
    24
    Quote Originally Posted by JamesW View Post
    Thanks for the reply. Cell is two years old. It was cleaned with Muriatic acid a week ago. Salt is 3600. With the power cable disconnected from cell, the voltage across the terminals of the cable was measured at 16v.
    Can't really tell unless voltage and current is measured while producing. See what that shows.
    Support the site
    Dec 2015
    Montverde/Florida
    24
    Thanks.
    Voltages measured a few minutes ago ( 11 am EST ) are as follows:
    1. With power cable connected to cell : 33v between cell terminals 1 ( outside left ) and 2 ( middle ). 32 v between terminal 2 and 3.
    2. With power cable disconnected from the cell: 4.4v between 1 and 2, 3.6v between 2 and 3.
    3. Voltages at the disconnected cable: 11.5 between 1 and 2, 11.5v between 2 and 3.
    33 volts usually means that the system has maxed out the voltage in an attempt to get sufficient current. Check amps going to cell. Get a multimeter that can do 10 amps passthrough and put it inline with one leg. Disconnect one leg where the power cord connects to the power supply. The current will pass through the meter. Make sure that the meter is configured properly or things will be damaged.
    Support the site
    Dec 2015
    Montverde/Florida
    24
    Thanks, JamesW.
    Couldn't measure current until this PM due to bad weather. I measured the current going through the cell by using the procedure given in the AquaPure manual: by measuring the voltage across terminals K & H on the front board. Voltage measured fluctuated wildly between 37 mV and -1.1 mV. Since 20 mV equals 1 amp., thus, the current going through the cell fluctuated between 1.85 and -0.55 amp.
    Maybe bad prongs. If the cell is under warranty, file a warranty claim. If not, you can remove the prong cover and see if the prongs are loose.
    Support the site
    Dec 2015
    Montverde/Florida
    24
    Checked the 3 prongs on the cell. They are tight.
    Look in the cell at the plates to see if they are eroded. Look at the center plate very carefully with a good light.
    Support the site
    Dec 2015
    Montverde/Florida
    24
    Thanks JamesW. I looked at the plates very carefully. They are clean and not eroded.
    If you're getting voltage to the cell but low current, it's probably a bad cell.
    Support the site
    Dec 2015
    Montverde/Florida
    24
    Thanks, JamesW for all the help.
    Dec 2015
    Montverde/Florida
    24
    JamesW,
    Just want say thank you again for your help. Your diagnosis was correct. It was the cell. I put in a new PLC 1400 yesterday. The error message went away after that. It was an expensive fix. My cell was only 2.5 years old.
    Jun 2011
    Long Beach, CA
    2,841
    Quote Originally Posted by lcchan View Post
    JamesW,
    Did you check to see if it was under warranty, the cell should have been covered for 3 years.
    Dec 2015
    Montverde/Florida
    24
    Quote Originally Posted by ping View Post
    The cells only have a 1-year warranty. Even my new one.
    Jun 2011
    Long Beach, CA
    2,841
    Just looked it up and you're right. It seems all the manufacturers are switching their warranties to shorter terms and/or require "professional installation".
    I've personally never had any salt system last through its warranty period yet, but they have all replaced the cell for no charge.
    If you have the old cell, remove the two screws that hold the plate that seals the prongs and pry off the cover plate.
    Also, look carefully at the titanium plates with a flashlight to see if they are damaged.
    It won't matter now that you have a new cell but I'm interested in how these cells fail.
    It's probably going to be one of the above things.
    Support the site
