Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Chlorine
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Question: someone told me that if you have too much chlorine that will cause you to get algae..... Is this true?
    15,000 gal 16x32 above ground, aqua pro 2 hp cartridge filter, Hayward skimmer
    38,285
    Re: Chlorine
    No. That does not make any sense.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,525
    Re: Chlorine
    Too much stabilizer, yes. But not too much chlorine.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    Yea I thought so, just wanted to make sure, when you say to much stabilizer, how much would be too much?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Chlorine
    Too much for the amount of chlorine you have. Chart in sig.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    38,285
    Re: Chlorine
    The required FC level is a function of your CYA level according to this: FC/CYA Chart
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    Just checked my CYA and it came to 80. That's pretty high huh? I think I started out at 50, could this be why I'm getting algae again?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Chlorine
    Are you using chlorine tablets or powdered bags of "shock".
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    Liquid chlorine
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Chlorine
    How are you testing for CYA? It won't go up without adding some.
    Look at the chart referenced above, and read this:Pool School - ABCs of Pool Water Chemistry
    If your chlorine level was below the minimum of 6, it would cause algae to take hold.
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    That's the thing, I keep my chlorine level high, in fact it's at 11 right now, all other levels are where they should be.... I tested the CYA with the test kit....
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    Actually I used chlorine tablets in the beginning so I think that's what brought my CYA up
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Chlorine
    You are correct. Each tab adds almost as much CYA as it does FC. But the CYA doesn't go away so...
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    I recently went back to the tablets to keep the chlorine steady then when it gets low I add the liquid chlorine...... Should I stop using the tablets?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Chlorine
    Yes! They are adding CYA and messing with pH. There is a spot at the bottom of the Pool Math page that goes into detail about it.
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    And I just checked the CC and it read that there is none, in assuming that can't be good
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Chlorine
    If your pool was 5000 gals like mine. Adding 8oz of trichlor (approx 1 puck) will raise FC by 11, raise CYA by 6.7, lower pH by 0.59, and raise Salt by 9.
    CC of 0 is perfect. Did you mean FC?
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Chlorine
    Mine is 15,000 gallons cartridge filter, not saltwater
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Chlorine
    That's easy. Divide my numbers by 3.
  20. Back To Top    #20
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    Re: Chlorine
    Welcome to the TFP Forum! You might go here: Pool School - Getting Started. That way we can have a better idea of what you're working with - and we'll help you figure it out.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
