Thread: pentair vs pump
    Apr 2016
    marana az
    8
    pentair vs pump
    Went out to turn on pump and the basket looked really low on water. Added water before turning on. Shut off and checked it about an hour later. It was about 1/4 down.
    My question is, should it be low on water after sitting for a few hours. I have a vacuum relief valve that is leaking. Could that be the cause. Any suggestions would be greatly appreciated.
    Thank you, Tim
    15k, in ground concrete with spa, aqualink rs, pentair intelliflo
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: pentair vs pump
    Yes, that could be the cause. No, it should not lose water out of the pump basket.
    Apr 2016
    marana az
    8
    Re: pentair vs pump
    So when it's shut off the vacuum relief valve starts to suck in air. Seems like I can hear the filter gurgling also. Is that normal?
