Thread: Chlorine neutralizer
    Aug 2016
    surprise az
    1
    Is it necessary to neutralize the test water before testing for PH and chlorine?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Chlorine neutralizer
    What do you mean?........and............NO!
    Chlorine neutralizer is used only on the TA test (reagent r-0007 thiosulfate). It wouldn't make sense to use it on a chlorine test. The ph test can be affected by high chlorine, but the reagent already has built in chemistry to handle chlorine up to 10 ppm. Over 10 ppm, the ph test can be affected. Neutralizer is generally not recommended as it can affect the ph test.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    What test kit do you have?
