Thread: Raised Spa needing to have different sized coping??
    Mar 2015
    Surprise, AZ
    1
    Our PB is telling us that our raised spa needs to have 8x16 coping, while the rest of the pool will have 12x12. Does that seem right to you all? They said it won't look right otherwise, but I can't find any pictures or info on the subject. unnamed.jpg
    Jul 2016
    Rancho Cucamonga, CA
    231
    Re: Raised Spa needing to have different sized coping??
    Our spa is raised (a lot) and the coping is about the same... we had an issue on the side of the pool where it is raised above the patio as the gunite was shot too thick and the shell was simply thicker on that side. We came to the conclusion that that side of the pool could be a few inches wider for the coping because it's a 'seat'... so, while it came from a mistake, we thought it would work out, and thus far, it looks fine.
    Best I can say, is take some cardboard and cut it to the different sizes, and lay them up there... see how it looks. One thing for sure though is stick with what YOU want, don't let your PB tell you otherwise (they can advise and are the (supposed) experts, but it's your pool).
    Pool-15x31', Spa-7x9', depth 3.5-6', HP Pentair Whisper Flow pump/motor, Intelliflo 8-160, 4-to-8 speed, Pentair 320 Clean and Clear capacity filter (upgraded to 400,000BTU stackless heater). Stacked stone- Autumn Rose Classic, tile- Ridgeline Blue Slate, coping- Turning Leaf Quartzite. Start date 7/12/16! Progress thread
    Jan 2014
    Southern California
    58
    8x16" why such a skinny flagstone size? I would go with either everything the same (12x12") or go bigger on the spa but not smaller (just my opinion). I went up to 18x18" on my raised spa and 12x12 on the rest of of the pool. We wanted a the bigger flagstone to accommodate a larger seating area around the spa. I'll try to post a picture in a few minutes so you can see an example.
    Jan 2014
    Southern California
    58
    Here's a picture of our spa sorry about the quality but I haven't took any good recent pics since completion.
