Thread: Taylor K-1000 Readings
    Jan 2016
    Oklahoma
    69
    Are the numbers in columns FC? So if the color matches the 4 spot, is my FC 4?IMG_2018.JPG I know one number is for chlorine and the other is Bromine I think.
    Vinyl, 20' X 44' in-ground, 35,000 gallons, Inteliflo VS 3HP, Triton TR-100 w/ activate, MasterTemp 400,000K LP, Dolphin Supreme M500, Hydramatic Hydraulic Auto Cover, TF-100 Test Kit.
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Taylor K-1000 Readings
    The first column of numbers under Cl are for chlorine. The second column of numbers under Br are for bromine. This applies to the left/yellow side. Ph readings on the right/pink side.
    So if you are matching the 4 that is for bromine and 2 is your chlorine reading.
    IG 15,000 gal vinyl Grecian SW, Hayward SWG, Pentair whisper flow pump, sand filter, Aquacal ice breaker heat pump. Finished August 2015, screen enclosure, TF 100
    Aug 2014
    Northern IL
    4,615
    If there are drops in the left vial, your FC is 0. May I suggest using the FAS-DPD test for your FC/CC?
    Your pH looks very high, but it could be the pic.
    Jan 2016
    Oklahoma
    69
    That was an old pic for reference. My pH currently is 7.3 or so. Is the Cl accurate enough to plug into pool math or do I need to do the power test that's in the TF-100 on a daily basis to maintain my Cl?
    Jul 2014
    Hope Mills, NC
    567
    I use the block 2 or 3 times a week to verify that there IS chlorine, and that the yellow is dark enough to be near the 5 level, and that the pH isn't getting too high.
    The TF 100 gets used about once a week now that I have everything pretty much dialed in and stable.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
