Results 1 to 8 of 8
Thread: Planning a new pool...deep end design?
    Aug 2016
    Pittsburgh PA
    316
    Hi everyone....new guy here. I've read and read and read but thought I'd try a post here to see if there is anything else I should consider.
    I'm in Southwestern Pennsylvania and recently built a house in a new development. We are putting in a 16x36 rectangle with a 3.6ft shallow and a 6' deep end (water height ends up being about 5.5ft). We want a 'usable' pool and are not interested in a diving board. We will be getting a slide though.
    Our deign has corner steps with an 8' bench coming off in both directions. The pool will start to slope at the 9' mark - just past the end of the bench. So it will drop 2.5' over the next 25' (or about 1" per foot). We are doing a "wedge" shape in the deep end so the slope goes almost the entire way - then slopes up at the wall.
    This is my question....are there any 'cons' to doing a wedge design? I suspect anything that sinks will all accumulate at one spot (in the wedge). But the slope is very gentle. We figure the longer slope and more gentle slope makes the pool more usable as your not standing on a steep slope.
    Anything else I should consider?
    Here is a wedge:
    Here is the more traditional flat bottom:
    Aug 2016
    Pittsburgh PA
    316
    Re: Planning a new pool...deep end design?
    I just found the "Under Construction" forum. Perhaps my post is better suited there? Please move if needed.
    Jul 2015
    Landale, PA
    107
    We just finished our pool and based upon what I experienced so far the gradual slope is much nicer. Will your pool have main drains? I would think that would be necessary if you have a wedge at the bottom, but there are many educated people on here who will be able to comment.
    Good luck with your pool build!!
    To be built Spring 2016. 750 sq foot gunite free form. Raised spa with spillover and dedicated pump, 16 foot fiberglass slide built into hill with bolder steps, approx 1,000 sq foot stamped concrete deck, Pentair VS+SVRS pump, Sta-Rite 400,000 btu gas heater, Sta-Rite System 3 cartridge filter, Pentair Intellichlor IC60 SWG, Pentair Intellichem, Pentair Easytouch, Rapids 4WD pool cleaner, 2 LED Intellibrite lights.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What type of pool surface will you have?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2015
    Central Valley CA
    1,107
    My standard recommendation is go a bit deeper on the shallow end it is more comfortable for adults to stand in 4' water vs 3.6'. That is our one regret our shallow end is 3.5' 6 inches does not sound like much but still wish we had done it. Often times people want shallower because of their kids but don't forget kids grow but the pool won't
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Aug 2016
    Pittsburgh PA
    316
    Quote Originally Posted by harleysilo View Post
    Its vinyl.
    You're probably correct about the shallow end being too shallow. I thought 3'6" shallow was the industry standard?
    I'm not sure I'll be able to sell the wife on changing that one. But that's part of the reason I wanted the wedge design the entire length - so the 3.5' will only be in the first 9' of the pool - then it starts dropping.
    Jul 2016
    Holly Springs, NC
    85
    The option for 48 inch walls vs the 42 inch standard walls exist. We were quoted a $3,000 upcharge for our pool. Like you, we aren't doing a "deep" end and are happy with our decision. We ended up going with the standard depth shallow end, too. I float. Don't care if it is in 2 feet of water or 8 feet of water as long as I can see bottom.
    43x31x20 lagoon shape, vinyl, inground pool. Approx 27,000 gallons. 3.5' to 5.5' depth. Latham natural gray liner, Pentair Tagelus fiberglass sand filter, Pentair Intelliflo pump, auto SWG, 3 LED intellibrite lights. Construction beginning Aug 11, 2016. K-2006C test kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Industry standard and what people like most are not always the same thing, you will find that the pool industry is VERY slow to change about some things, and shallow end standard depth is one of them, and if you ask why you are likely to get an answer like because that is the way it has always been. As to the slope issue I feel a flat bottom area is fairly important, particularly if you have kids that are still learning to swim. Having said all that the traditional hopper design pool with shallow end is a compromise design (I have one that was built 36 years ago), it is sort of the mini-van of swimming pools, it is economic for its size and capacity, is efficient use of space and does an overall ok job, but not really great at any one thing... Having said all that, there are some really interesting designs that can be done with vinyl pools if you have the space, such as designs made from 3 overlapping rings, here is a build thread that comes to mind Update - Water In - Final pieces remain South Jersey Build it gives a good idea of what is possible in a vinyl pool.
