Results 1 to 7 of 7
Thread: Liquid chlorine
    Jul 2015
    England
    34
    Liquid chlorine
    Hi all I am in the uk and quite new to all this and I'm currently trying to source liquid chlorine of a higher percentage than the less than 5% tesco sell. When I came across this website http://www.farmchem.co.uk/sodium-hypochlorite-1415. Not sure if this is the correct stuff or even if that link will work. And if it is the right stuff is that good value?? Many thanks Nathan
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Liquid chlorine
    All liquid chlorine, liquid shock and bleach is the same stuff, sodium hypochlorite with various percentages of chlorine.
    In the US it is usually as follows
    Bleach, 3 to 8-1/2% sodium hypochlorite
    Liquid chlorine 10% sodium hypochlorite
    Liquid shock 12 to 12-1/2% sodium hypochlorite
    Jul 2015
    England
    34
    Re: Liquid chlorine
    OK thanks. So this stuff for would only be good for shocking the pool as it's 14%. It would be unsuitable for day to day use like you guys do with bleach?? Thanks for your help.
    DFW, TX
    24,497
    Re: Liquid chlorine
    It is fine for either purpose. Just be sure to adjust the percentage in PoolMath so you get the correct dosage. i.e., use half as much 14% as you would 7% to achieve the same ppm FC.
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    78
    Re: Liquid chlorine
    If you use the pool calculator app http://poolcalculator.com/?utm_sourc...aign=redirect/ you can input the percentage of the bleach and the readout will give you the exact dosage.
    14,000 gallon Fox Lagoon, ingound vinyl
    PacFab Sand filter
    installed April, 2002
    Frog inline chlorinator
    Town water
    Jul 2015
    England
    34
    Re: Liquid chlorine
    That's brilliant thanks you
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Liquid chlorine
    Note: Pool Calculator is not being maintained. I would recommend using Pool Math instead. It's right up at the top of the page
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
