Thread: Horrible chlorine smell
    Jun 2016
    victorville ca
    16
    This mornings numbers
    FC-12
    CC-.5
    PH-8.0
    TA-150
    Sunday mornings numbers
    FC .5,
    CC-1.0
    PH- 7.6
    TA-120
    Had the beginnings of an algae bloom (ran out of chlorine for a day). Water never got cloudy always crystal clear, but had two small slimy spots which I scrubbed up. Sunday tested, slammed Sunday night, all day Monday. Monday nights Overnight test lost no FC, but this morning the smell of chlorine fills my back deck. I should be done slamming by my test results. Why the major chlorine smell? It hasn't smelled this bad ever. I added PH decreaser to bring the PH and TA back down.
    15 x 42, 4600 gal, AG summer waves, vinyl, SkimmerPlus 1000 filter pump, K-2006
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Horrible chlorine smell
    Can you post test results from this morning? CYA also please.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Horrible "chlorine smell" is CC. CC is high because the chlorine is oxidizing some organic matter and because FC is too low to burn off the CC.
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    In order to determine if your FC level is adequate, you will need to determine your CYA. The higher your CYA, the higher your FC will need to be to sanitize your water.
    Extended Test Kit Directions
    Check out the above link for detailed directions on how to test for your CYA level. You can then use Pool Math to figure out how much bleach to add. Good luck!
    22,400 gal; in-ground gunite rectangle, vinyl liner; 3.5'-8' depth; Chlorine; auto cover; Hayward Pump and Sand Filter; Hayward Electric Heatpro; diving board; 3 sidewall fountains; open mid May thru mid October; built 2011; Taylor K-2006C FAS-DPD Test Kit
    Jun 2016
    victorville ca
    16
    Sorry I realized I didn't include my CYA
    this mornings results:
    FC-12
    CC-.5
    PH- 8.0 added decreaser have not retested yet
    TA-150
    CYA- 30
