Results 1 to 9 of 9
Thread: Constant Rain - Advice needed
    Simmer's Avatar
    Aug 2016
    FLORIDA KEYS
    42
    Exclamation Constant Rain - Advice needed
    Hey Guys, over the last several days I have been trying to raise my FC and PH. The problem I am having is the constant rain in the Florida Keys. There is a tropical storm south of us, but we are being crushed with rain. Should I hold off on adding chemicals and trying to get my numbers inline? My daughter was going to have a pool party this weekend for her 3yr BDAY, but I don't think its going to happen.
    I cant be the only one with this issue, so I a reaching out for advice. The numbers are skewed each time.
    San Juan Mandalay Bay / Saltwater Fiberglass IG / Installed 2012 / 6600G / Depth 5.7 / Digital Nano #75041 / RC 35.22 / Sta-Rite SuperMax 2HP 1-Speed / Hayward C12002 Cartridge Filter / AquaCal 74K BTU / Silencer Air Blower 1.5HP / Taylor K-2005
    Jun 2014
    15,221
    Re: Constant Rain - Advice needed
    Definitely keep an eye on pH and FC. Remember the heavy rains will also tend to lower CYA if overflow continues for an extended period of time, so you may want to confirm that later. But for now, make sure you always have adequate FC to prevent an algae bloom. You can easily check pH as well just to make sure it doesn't start to get too high on you. Hope that helps.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,286
    Hello, fellow Floridian!
    Fine and preferable to balance your water even in the midst of all the rains. You don't want to give room for algae to gain a foothold.
    Best wishes for decent weather for the party!
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Another fellow Floridian here. Believe me, this rain is nothing compared with an actual hurricane. I had to drain about four inches today up here in Central Florida. Keep your eyes on it. Test daily until the storm passes. Your daughter is probably too young to thank you, but her safety is more important than a few extra bucks of bleach and HCL. Good luck and we'll be thinking about you in a few days when it turns and drenches us!
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Simmer's Avatar
    Aug 2016
    FLORIDA KEYS
    42
    thanks everyone! I appreciate the Floridian kind words and guidance. I will continue to monitor and test everyday until the weekend. I have most of the specs inline with TFPC.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,286
    How is your weather looking today, Simmer? We are getting pummeled today!
    Aug 2014
    Northern IL
    4,615
    Best wishes with the weather, Simmer!
    Simmer's Avatar
    Aug 2016
    FLORIDA KEYS
    42
    hey everyone. Believe it or not around 90 degrees and no rain at all. Hermine went underneath us and hooked up into North Florida. Poseidon spared us this time.
    Tomorrow is the pool party. Im going to test tonight and make any final adjustments Im running my pump all night and put BOOST on this morning. I anticipate a lot of swimmers tomorrow.
    Aug 2014
    Northern IL
    4,615
    Yay! Y'all have fun!
    Btw, did you ever get the FAS-DPD upgrade to your testkit?
