Thread: Remove return jet fittings
    Jun 2016
    Boston, MA
    138
    Hi,
    i was adjusting eyeball fitting on returns yesterday. Maybe I tighted too much by hand, now I cannot move the fitting by the hand at all. Which tool should I use? I have channel lock plier at home, but really afraid of breaking the plastic fittings
    first time adjusting return direction, and feel so frustrated...
    Massachusetts
    Vinyl Salt Pool 2011; IC40 SWG; Raypark gas heater; Sta-Rite Dynapro pump; Sta-Rite System 3 Filter S7M120; Pool size: app 25000 Ga
    first time pool owner. First year too.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Mine get that way too. Generally I can just put a towel over the return for extra leverage and I untighten by hand. If you're going to use a channel lock, just put a towel between the tool and the return. I will say return jets are pretty cheap if you do end up breaking it. About $5 at most pool stores.
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Jul 2012
    Cary, NC (Raleigh)
    69
    Re: Remove return jet fittings
    Try a rubber strap style adjustable wrench...more commonly as an oil filter wrench. Pick up at any auto parts store for probably less than $10.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    Quote Originally Posted by blbncsu View Post
    These work perfectly (see pic below if you're not sure what it is). I use for just that purpose (loosing return jets). Can also use an set of channel lock pliers, but need to be really careful with those to not press too hard or you could crack.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,384
    Sp-1419t
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Quote Originally Posted by PoolguyinCT View Post
    Sp-1419t
    This is the tool used to tighten/loosen the eyeball itself once the jet assembly is removed. It is used on the backside of the jet.
    Hayward Pool Products | Seat Removal Tool | SP1419T | 30750 | 610377047715
    I use o-ring Lube on the threads of my eyeball jet, helps to keep it from getting stuck (as long as you don't over tighten it).
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
