Thread: Leak in my mid pool return line
    I've had a significant leak, about 1/2 an inch of water a day in my 16' x 32' pool. I built a pressure tester and found the center, 1 of 3, return line leaking. It's a major leak as the hose shows no pressure when my hose is full open at about 1.6 gal per minute. Years ago I moved the pump and heater. My local pool installer did the work using flex hose to connect to the original PVC pipe. I suspect a connection failure at the pump end or the original equipment location. I plan to check the connection at the pump first. I donít see any water pooling when I pressurize the line with hose, my yard is very sandy. Any suggestions would be appreciated.
    Jim
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Leak in my mid pool return line
    Sounds like you have a decent starting plan - If you know where those suspect connections are, take a look.
    Found it at the 90 coming up to my valves, easy fix, the glue failed at the joint.
    Jim
