Results 1 to 8 of 8
Thread: Pentair ic20
    May 2014
    United States
    5
    Pentair ic20
    i bought a Ic20 it work well for a week now the lights for the percentages are flashing green in order
    my salt level are 3400 this is a 2 weeks old. theres also condensation that i don't know where its coming from
    any help ?
    16,000 gallon gunite with 800 gallon spa. 450 mm pentair filter. circulation pump sta-rite VS-450
    400,000 B.T.U. pentair max-e-therm heater @ spa. 2 water pots.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,545
    Re: Pentair ic20
    simnala,
    If the unit is in the "Boost" mode, the output lights will flash left to right.. Push the More and Less buttons at the same time to shut off Boost.
    I noticed two thing that concern me..
    1. The salt light is not green.. or red.. I'm not sure why that would be???
    2. An IC20 for a 16K pool is way undersized. My guess is that you will need to run the unit at close to 100% for 24/7 to produce the amount of chlorine needed.
    Is this unit connected to an automation system?
    Think maybe you could narrow down your location a little??? Hard to give any advice is we don't have a general idea of what your climate conditions are..
    May 2014
    United States
    5
    Re: Pentair ic20
    i used to have a 1c40 for over 6 years. the cell some blades fro the cell broke. and when i ask around my location i was i told why you had a Ic40 for the size of yr pool... so i bought the ic20... i should asked here. my backyard faces south so i get the morning sun by 2:30 pm my pool is complete shaded
    yes is connected to a easy touch system i live in the central valley in california
    i was Told that IC20 was for 20,000 gallons or less and the IC40 is for 40,000 gallos or less
    Mar 2016
    Chino Hills, CA
    190
    Re: Pentair ic20
    I believe the lights may flash if the percentage is not at 20, 40, 60, 80 or 100 through the Easytouch.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Pentair ic20
    That is correct, it flashes the percentage it is closest to when Easytouch has it at say, 43%.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Pentair ic20
    There is something up with that unit. You should not have condensate inside like that. Call Pentair and see about warranty right away. There is a serial number sticker, should be on the underside of the cell, have that ready when you call.
    1 800 831 7133
    Factory Warranty Station for:
    May 2014
    United States
    5
    Re: Pentair ic20
    since i bought from amazon pentair told to contact amazon... amazon had contact the the seller and I'm waiting for a respond. i will have the send me a IC40 and will pay for the difference. thank you for the help
    donaldm823's Avatar
    Cape Coral, FL
    147
    Re: Pentair ic20
    Quote Originally Posted by simnala2 View Post
    any help ?
    Had the same symptoms with a new IC40 I bought from Amazon. Turned out to be an internal water leak that was faulting the electronics. After 2 days, I sam water dripping from the control panel face opposite the salt light. You need a new cell!
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
