Thread: New Pebble Finish - Algae Problems.....
    Aug 2016
    Houston, Texas
    2
    Information about my pool:
    DE Filter
    24,000 gallon pool
    Just had a new dark blue pebble finish (dark blue quartz and black glass finish) installed 2 months ago.
    Chemical Balances:
    PH – 7.8
    FC – 4
    TC – 5
    Total Alkalinity – 100 ppm
    Calcium Hardness – 270 ppm
    CYA – 50
    Recently cleaned my filter and added new DE powder. Water temperature about 90 degrees (Houston – summer time)……
    It appears to have good circulation and balances remain within the normal requirements but every week I’m seeing more green algae growth on the sides of the pool…..
    We have had some serious rain in the past month.
    Does anyone have any suggestions as to why I’d be seeing algae growth with the numbers above? I didn’t have this problem with a plaster finish. Would adding algaecide help or is there something else I’m missing?
    Jun 2016
    Austin, TX
    334
    Re: New Pebble Finish - Algae Problems.....
    What kind of test kit are you testing with?
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    Aug 2016
    Houston, Texas
    2
    It was purchased at Leslie's Pools. It's a Taylor test kit that tests:
    Free Chlorine
    Total Chlorine
    PH
    Acid Demand
    Base Demand
    Total Alkalinity
    Calcium Hardness
    CYA
    It was recommended by a pool company who did the startup on the pool when the pebble finish was complete.
    Aug 2014
    Northern IL
    4,615
    You need to upgrade your testkit a tad with the FAS-DPD chlorine test. It's the Taylor K-1515C. It will allow you to test FC at much higher and more accurate levels.
    If you are seeing visible algae, you NEED that ability.... And you need to slam. See this:
    Pool School - SLAM - Shock Level And Maintain
    Last edited by MarianParoo; 08-29-2016 at 11:05 PM. Reason: Link didn't show the first time.
