Results 1 to 7 of 7
Thread: High PH and Filter Cartridges
    Hi,
    I have a 10,000 gl. above ground, and have had trouble with the water flow through my cartridges becoming restricted. I get a new cartridge and within a few weeks I go from 11-12 lbs. on the gauge, to 18-19...and with no "visible" debris on cartridge. I can take it out and hose it off, and it'll go down to about 14lbs., but will be right back up to around 18-19 lbs. about an hour later. And of course at that pressure there's very poor circulation.
    I've also recently discovered I wasn't accurately testing my ph levels. Now I am thanks to recommendations I've received on this site, and I found out my ph levels have been at least 8 or above. Been struggling to keep chlorine levels up as well. My water is clear but I've been adding chlorine like crazy!
    I've got the ph down now to between 7.4 and 7.8. Could the restrictions in my cartridge be tied to the chronic alkaline water I had? Thanks for your time
    Sincerely,
    Jeff
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,520
    Re: High PH and Filter Cartridges
    Rain,
    Well, the good news is that your cartridges are working just fine. The bad news is that your cartridges have something to work with....
    90% of the time (I just made up that number) what you are experiencing is algae.. Clean cartridges work fine, but after a few hours of collecting dead algae, they can no longer pass water easily, and the pressure goes up. This has nothing to do with pH.
    The fact that you are having to add chlorine "Like Crazy", is just another indication of a possible algae outbreak.
    How are you testing your pool water? Please post the following test results:
    FC
    CC
    pH
    TA
    CH
    CYA
    These number are all interrelated, so they are all important in any advice we can provide.
    Ok I will post the numbers as soon as I get them
    Hello,
    Here are my results…
    TC-5
    FC-4.5
    PH-7.8
    TA-140
    CYA-None?
    Hardness-150 or 500
    Sorry about the last 2 values! The hardness reading of 150 came from my tft testkit, BUT my reagents are a couple of years old. The 500 came from a test strip. The strip also showed a 30-50 reading on the CYA, but the test kit indicated none, as I could easily see bottom of test tube after filling…no cloudiness at all.
    I used 3” pucks for years and then discovered my CYA was off the charts. So I drained of the water and have been using nothing but liquid chlorine every since.
    I really don’t think my issue is algae, at least none that I can see. When I rinse the cartridge there’s no green. It’s just a sandy tan color, and my water is clear. So I’m not sure what’s happening to my cartridges after a few weeks with rising pressure? I thought maybe the high alkalinity was causing scaling to clog it? If not, then I’m stumped. Thanks
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    That sandy tan color is likely dead algae. Do an OCLT :Pool School - SLAM - Shock Level And Maintain. Algae doesn't show up until it is at almost catastrophic levels...then it quickly becomes a catastrophe. Remember the motto: "MORE BLEACH!"
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Also, bring your CYA up to at least 30 ppm so you can read it on the test. Without CYA, the FC will not last long during the day which can be part of your problem.
    Mark
    Thanks everyone! I'm going to employ your advice and report back.
    You guys are great.
    Jeff
