Results 1 to 8 of 8
Thread: testing for bromine- is it chlorine or bromine?!
    Jul 2016
    Gainesville, FL
    126
    I primed the spa with sodium bromide, added chlorine as oxidizer (2-step method outlined in the sticky post). I am using Taylor K-1000 to test for bromine. Question is, is it chlorine or bromine I am looking at?! they both use the same reagent (OTO) so I have no clue if I am measuring the oxidizing bleach that I added, or the sodium bromide turned into bromine? Do I need to wait a certain amount of time for the chlorine to do it's magic before measuring bromine levels?
    Also, I understand it is recommended to use Taylor K-2106 for bromine. Is it another color-matching kit? or will I be counting drops? there is surprisingly little information available on this kit, I would like to know how it works before spending $57.
    Inground 28000 gal Concrete, Hayward Progrid DE filter 6020, US motors 1.5hp pump (3450rpm) , Polaris 360
    600 gal hot tub, Spa Vita, Nature2+MPS
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: testing for bromine- is it chlorine or bromine?!
    I am not very familiar with bromine but this should help until somebody comes along.
    How do I use Bromine in my spa (or pool)?
    May 2012
    Toronto, ON
    463
    I have been told that you can just use the test chemicals for chlorine and multiply by 2.25 for bromine. So when using the FAS-DPD chlorine test kit to test for bromine for a 25ml sample the FC reading is drops*.2*2.25 or drops *.45. So just using drops*.5 is close enough. This makes it easier for me to use one kit to test my SWCG chlorine pool and bromine spa.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    JoyfulNoise's Avatar
    May 2015
    13,192
    You can't differentiate chlorine from bromine. The test should really be called a "total halogen" or "free halogen" test because chlorine, bromine and iodine will all make the dyes change color.
    In your spa, you just have to assume that the dominant halogen is bromine because chlorine will immediately react with the bromide to form bromine and it (chlorine) will be used up very quickly.
    Incidentally, this is why you should NEVER add bromine to a swimming pool. It creates a constant chlorine demand which cannot be accurately tested for.
    Matt
    Jul 2016
    Gainesville, FL
    126
    does this apply to FAS-DPD test also? e.g both chlorine and bromine will make it turn pink?
    May 2015
    13,192
    Quote Originally Posted by archer636 View Post
    Yes.
    Matt
    Jul 2016
    Gainesville, FL
    126
    Yes.
    then how come K-2106 is indicated for bromine testing and not chlorine? or is that just a marketing gimmick?
    May 2015
    13,192
    Marketing gimmick. The K-2106 has the FAS-DPD titration test for halogens, pH, TA and CH tests. That's all that matters in a bromine spa because one does not use cyanuric acid in a bromine spa.
    In general chemistry terms, the DPD indicator dye turns pink in the presence of any halogen (chlorine, bromine and iodine). It does not distinguish between halogens.
    Matt
