Results 1 to 8 of 8
Thread: Probably going to be in trouble for asking this question
    Aug 2015
    Upstate, NY
    13
    FC: 4 mg/l
    CC: no reading, zero?
    pH: 7.4
    TA: 60 mg/l
    CH: 50 mg/l
    CYA: 35
    Hello - I am in the process of starting up a DYI pool. I had a temporary filter set-up with the intake just dangling into the side of the pool. I used a long hose to direct flow to one set of returns. At the same time I had my sump pump polyfill bucket going to remove some iron content I made the mistake of introducing through a garden hose top up. I managed to pick up a aquabot robot and although a wreck to look at (buckets, dangling hoses, no coping etc.), I had really beautiful sparkling water. Even when the water was orange, it was perfectly translucent (just orange). Sat. morning I move the filter to its permanent location. First time it was drawing from the skimmer and returning to all four outlets. Brown horribleness shoots out of the two returns that had not been in use before this point. While my levels still look good (day before brown jet infusion my pH was at 7.2) my water is now cloudy. I have run the filter straight since Saturday morning and used the robot twice. The water quality does not look like it is improving.
    Am I really back to SLAM? I don't want it to get any worse, but everything was going so well....
    7,000 gallon DIY CMU w/ Vinyl Liner (Golden Pebble) - Cartridge Filter - Taylor 2006
    Jul 2015
    San Marcos, CA
    110
    Re: Probably going to be in trouble for asking this question
    If you're passing OCLT, then you shouldn't need SLAM anymore. It may just be a question of filtering at this point.
    16 x 32 IG plaster pool, 23k gallons, built 1992, DE filter, Pentair VS pump, IoThyngs controller, Taylor 2006 test kit, SoCal water restrictions
    Newbies with green pools, see SLAM and Recommended Test Kits. My company: IoThyngs
    Aug 2015
    Upstate, NY
    13
    OK OCLT tonight, I have not done that since the incident. I will report tomorrow am.
    Thanks!
    30,431
    Why are you posting mg/l test results?
    Why are you in trouble for asking questions?
    Aug 2015
    Upstate, NY
    13
    Hello -
    I passed the OCLT test with no problem. Less than 0.5 mg/l drop overnight.
    duraleigh - mg/l = ppm (Professional habit to use mg/l, I will try not to do it if it causes confusion)
    Before posting I read, and read, and read - 'Help I have cloudy water' posts. In almost every case, the answer is SLAM. So I felt like I am trying to avoid doing the obvious, or avoid following pool school by asking the question, which past threads have answered time and time again. So my CC is 0, my OCLT is <0.5, but I have cloudy water. I am failing the third SLAM rule.....
    Aug 2015
    Upstate, NY
    13
    Amail, you were right, and I was not patient enough. Finally today we are clearing up. You know, I was thinking about the weekend, and in addition to the brown water from the return, there were three kids in the pool slathered with SPF 50. I imagine that didn't help either.
    Thanks you.
    Jul 2015
    San Marcos, CA
    110
    Good to hear! Keep an eye on FC while your filter plods along - you'll be there soon enough.
    30,431
    nire878,
    mg/l is confusing....every one is used to ppm.
    If it's a chemistry questions 85% of the answers will be to add chlorine. Most new pool owners don't understand that nor are willing to do it. You are not being repetitive....we see it a hundred times daily.
