Results 1 to 10 of 10
Thread: 'Less is more' winterizing plan. Thoughts?
    May 2016
    Denver, CO
    7
    We’ve got a 16’ round Doughboy metal frame pool, and this will be our first winter with it here in snowy Colorado.
    I was looking at the micro mesh sort of winter cover idea, but I remembered what our 16’ trampoline (similarly rain-permeable) looked like the winter we left it up, all bowed nearly to the ground as two feet of snow started to melt… and I’m imagining that sort of weight pulling the walls of the pool in to collapse.
    Thanks to this forum, I’m not worried about being able to deal with a green pool should I have one in the spring. But a collapse is something else…
    What about going as simple as can be: drain the pool down below the skimmer and inlet, remove all the equipment so there’s a couple of holes in the side of the pool, essentially. Then leave the already-beat-up summer solar bubble wrap cover on to catch a non-zero number of leaves, and count on replacing that cover in the spring?
    My thought is with two feet of snow on top of the thing, it would displace water safely out the skimmer and inlet holes without putting horizontal pressure on the walls. Then when the snow melted it would be at a similar level. What am I forgetting?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: 'Less is more' winterizing plan. Thoughts?
    I did not even put a bubble cover on this last winter, just drained it down, blew out the lines and capped them, put a gizmo in the skimmer and called it a winter
    May 2016
    Denver, CO
    7
    Gizmo?
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    352
    Gizzmo. A device to absorb ice expansion in the skimmer: Amazon.com : Gizzmo 4102 Super Gizzmo in Big Deep Skimmers for Pool : Swimming Pool Covers : Patio, Lawn Garden. Link for information only, NOT an endorsement. I use a skimmer cover and return plug...but then if we get more than 2" of snow during the winter we're having a blizzard!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Unlike your trampoline, the water below the cover will support the weight of any snow piled up on top. So unless you drain it all the way, the cover will only droop to the surface of the water. I don't think you need to worry about strain on the walls.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Lisa_jolene's Avatar
    May 2015
    Wahpeton, ND
    19
    We had an intex pool last year and just left it uncovered.
    Now we just put up a metal wall pool and am also considering my options for winter. I am in ND where we can see tons of snow. I am really considering not covering as well.
    10,000 gallon 22x52 Intex Ultra Frame pool.
    Intex Krystal Clear Sand Filter/Pump (.75hp / 2150gph / 14" 77lb of sand)
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    331
    Cover to keep all the stuff out. It will make for easier clean up in spring. Leave the cover loose with floats or truck tire tubes secured in the middle of the pool to raise the center of the cover & allow for ice expansion. I use clips and the wire on my cover. Wire to hold firm and the clips keep the cover down & will minimize air under the cover. Water will move to the outside of the pool. You can drain from there. I use 3/8 clear tube inside of 3/4 Grey PVC conduit. Conduit supports the tubing and makes a low spot when draining cover. Off and on as required or it will freeze there.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jan 2010
    Randleman,NC
    620
    Learned my lesson on not covering pool.Liner,etc weather and become brittle from the cold.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Mar 2015
    Winfield, KS
    45
    My plan for this year is to do as I have in the past: drain to below the skimmer, leave cover on until most of the leaves have fallen and then just leave it open.
    Round 18' Sharkline pool, 8600 gallons of well water. Hayward 40gpm single speed pump and DE filter
    May 2012
    Montville NJ
    545
    The most time consuming part of my winterization is "detailing" my filter - I take it into the garage and go over it. Clean it very well, check all O- rings, lube everything, torque bolts down correctly, etc. Then it goes into storage.
    As for the pool. I run the FC way up there (clearly with the filter running) I drain it a bit - not below the skimmer though - just so it is halfway or less. I put a door on the skimmer, and I keep the skimmer lines open, so any rainwater drains out. I put a plug in the return and do the same thing - keep the return lines open. Then I put on a solid cover with a center float.
    During the fall, I try to keep the cover dry (I just start a siphon to get the water off) becasue i find if it is dry, then the leaves just blow off. Once the leaves have all fallen, then rain/snow/ice can all collect on the cover for all I care - in fact it helps hold the cover down. It really is not a big chore for me.
    One year I did have an issue. We had a long period of very cold weather, and the pool froze below the return, The wing nut on the return plug got caught in the ice, and when the ice shifted, it pulled out the plug. The pool drained down to the return. Not great, but in the grand scheme of things, not too big a deal either. I use a rubber plug, instead of a threaded plug because I have an Aqualuminator, which does not have interal threads.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
