Thread: DIY Safety Cover Installation with pavers
    Mar 2016
    Baltimore, MD
    33
    Hi All, just finished installing my safety cover and thought I'd post it up being that it's that time of the year. I haven't closed yet, but I wanted to have the cover ready to go for when I do. The only pool store I could get to give me a quote was the builder and they came back with $4700, I got a couple quotes from online places and ended up with a loop-loc mesh for around 2K. I have a paver deck and was very nervous about using a hammer drill and cracking the pavers so I went with a core drill. Here's a pic of the back of paver for a test hole drilled with a hammer drill and a core drill
    A much cleaner hole with the core drill.
    I laid out the ropes as per the instructions.
    This may not have been necessary with the water being high, but it wasn't that big of a deal to do.
    Ready to start drilling. The sleeves for inserts are 12" long
    the water attachment on the drill wasn't working. It should have been feeding water inside the core bit, but the quick disconnect didn't work, so I had to rig a hose. I think it would have worked a lot better if the water could have been feeding from inside the bit.
    This was when I realized I was going to be in for a long day. It varied on how far down the bit would go before it stopped because it couldn't push the material up the bit any further. I had to take the bit off the drill and then use a piece of rebar and a hammer to clean it out and then go back to drilling. Even after getting through the paver it wasn't always easy and the crush and run under the pavers clogged it up as well. With having to go 12 inches deep for each hole I ended up having to clean the bit out at least 3 times per hole and sometimes more. Here's a pic of the bit cleaning station.
    The cordless drill with a masonry bit was used sometimes to loosen the gravel so it would come out easier.
    Here's a pic halfway through
    And complete
    The waterfall area is 1 foot higher than the res of the coping and I was torn about going up and over, verses drilling into the tile or coping and putting anchors to go straight across. I chose up and over.
    The black flap you see is what they call the gap guard I think which helps keep things from getting in through the gap. I need to trim those when I reinstall in the fall.
    I'm not happy about how tight it is on the two high corners and even got this small rip at some point during the install.
    There is rubber padding under this and it didn't cut through that, but I got a patch kit and will patch it when I put it back on and put some extra padding on those corners.
    So all in all I'm happy with it, other than the rip, but hopefully I can keep that from happening again by being more careful. Maybe going across the tile/coping would have been better, but hopefully this will last a while. If I had it to do over, I would have rented a core drill and a hammer drill and used the core drill to go through the pavers and then use the hammer drill to go through all the gravel, dirt and rock. This install took 10 hours with the core drill due to the numerous time I had to clean it out, but no pavers were cracked so I'm happy.
    24K white plaster IG pool (2016), Jandy DE, Jandy 1.5 HP pump, Polaris 280 cleaner, Hayward H400DN heater
    Jul 2015
    San Marcos, CA
    110
    Re: DIY Safety Cover Installation with pavers
    That looks really nice! Much better than the bubble-wrap type that floats on the surface. Is the cover safe to walk on?
    16 x 32 IG plaster pool, 23k gallons, built 1992, DE filter, Pentair VS pump, IoThyngs controller, Taylor 2006 test kit, SoCal water restrictions
    Newbies with green pools, see SLAM and Recommended Test Kits. My company: IoThyngs
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    I've been researching this exact thing a lot lately. Everything I've read says that the holes should be drilled between pavers, not in the middle of them. I am interested to see how yours holds up over time.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2016
    Baltimore, MD
    33
    I think the bubble wrap type you mention is a solar cover for use when the pool is open, this is a winter cover.
    I'd heard that too, but I have some larger pavers and if I did that the holes wouldn't be anywhere near in a straight line, which is why I went with the core drill.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Great step by step with the core drill and I suspect you won't have any issues with your new cover. I used a tarp last year and although it kept my water near sparkling clear,, the wind blew it all spring. I plan on doing a loop loc install of my own, but will just use 1/2" mortar bit and hammer drill to install the deck anchors - as my deck is concrete.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
