Results 1 to 14 of 14
Thread: Catridge filters, how many years before replacing cartridge?
    Oct 2010
    michigan
    284
    Cartridge filter type, and how many years to replace cartridge?
    Thanks
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Aug 2016
    Georgia
    49
    Re: Catridge filters, how many years before replacing cartridge?
    Too many variables. But one of the worst things you can do for a cartridge filter is to clean it too often, it shortens the life.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It was 10 years for me.
    Mark
    Mar 2015
    Sugar Land , TX
    424
    Quote Originally Posted by JohnKrupp View Post
    Any hard evidence of this? I clean about 3 times a year, lot's of leaves and tree debris.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Aug 2016
    Georgia
    49
    Just experience. The high pressure hose nozzles take a toll on them and it tends to cause the bands to separate from the pleats.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You should never use a high pressure nozzle to clean your cartridge. Buy the simplest, cheapest nozzle that you can find. You are looking for a pencil sized stream but not lots of pressure. Hold at 45 degree angle and wash the debris away. Never point straight into the filter if you can avoid it.
    To avoid the need to clean so often, use a skimmer sock to catch the debris before is gets to the filter. There are many different types of skimmer socks available including pantyhose, paint bucket strainers, and hairnets.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2016
    Georgia
    49
    Quote Originally Posted by pabeader View Post
    I disagree. I don't mean a pressure washer but something that makes a very strong concentrated stream.
    I'm sure you can get by with a run of the mill nozzle but it'll take longer and require more effort to get the water deep into the pleats.
    here is my personal favorite Bullseye Nozzle
    Simmer's Avatar
    Aug 2016
    FLORIDA KEYS
    42
    thats a slick nozzle. I just replaced my cartridge this year, and I already cleaned it twice. I will monitor how gentle I do it.
    San Juan Mandalay Bay / Saltwater Fiberglass IG / Installed 2012 / 6600G / Depth 5.7 / Digital Nano #75041 / RC 35.22 / Sta-Rite SuperMax 2HP 1-Speed / Hayward C12002 Cartridge Filter / AquaCal 74K BTU / Silencer Air Blower 1.5HP / Taylor K-2005
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I used to use a brass nozzle which worked pretty well. Then I got one of these, Filter Flosser | Filter Flosser Cartridge Cleaning Tool It is a lot better. I prefer Pleatco filter cartridges to the OEM cartridges.
    Simmer's Avatar
    Aug 2016
    FLORIDA KEYS
    42
    thats another great looking nozzle. I use the Pleatco now as well. It was cheaper and the quality is great.
    Jun 2014
    Roseville, CA
    343
    Mine don't last more than a couple of years. I suspect sun screen lathered on the grandkids is a big part of the problem.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Chuckiechan View Post
    Just curious, exactly how do they fail? Do they get clogged and you can't clean them anymore? Have you tried the TSP/Acid process?
    Mark
    wjr75's Avatar
    Jun 2013
    IL
    836
    They will usually tear somewhere in between the pleats or the rubber hosing on each end may crack. At least that's what I have seen.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by wjr75 View Post
    Yes, I am aware of how cartridge filters normally fail. However, ChuckieChan indicated sun screen was the culprit so I am interested in why that would be in his case.
    Mark
