Results 1 to 7 of 7
Thread: Adding Borax - Why muriatic acid vs PH Down?
    Aug 2016
    Austin, Texas
    2
    After having our pool replastered at the beginning of summer, I took over the pool maintenance from my husband and have had wonderful luck with the TFP method. I'm planning to add borates via the Borax & acid method after reading such positive discussions on this site. I did have one question - I always use PH Down instead of Muriatic acid mostly due to convenience. Normally on the site, and in the calculator they are presented as either/or but everything I've been reading on adding borax only says to use the muriatic acid. I'm sure there must be a reason but wanted to understand why before I go making trips to Home Depot or wherever to buy muriatic acid.
    18800 gal, quartzscape plaster, DE Filter
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Adding Borax - Why muriatic acid vs PH Down?
    Another option is to use boric acid. Then you don't have to worry about the MA or pH down.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    You want to use MA with new plaster in particular as pH Down products leave sulfites in the pool which can be harsh on the plaster.
    Aug 2016
    Austin, Texas
    2
    I figured there had to be a reason - thanks for the quick response.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Boric acid "pellets" from DudaDiesel is the way to roll.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The Boric acid is the way to go. I did my 32K with 20 Mule Team and it's a lot of boxes and a lot of acid. If I have to dump the water and do it over again like when the liner is replaced I'd go with the one step Boric Acid.
    DudaDiesel - - > Google
    Solar Blanket, Well Water, Borax Added. 68
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Having done both the 20 mule team and boric acid methods, I agree. Just order granular boric acid from Duda Diesel. The total cost will be similar and it's so much easier. Just toss the correct amount in and brush it around a bit, and you're done.
    chiefwej
