Results 1 to 10 of 10
Thread: Member Map
    May 2016
    West Bloomfield, MI
    709
    Member Map
    I'm a member of other (non-pool) forums that have implemented a "Member Map" so we can at-a-glance see member locations.
    I think that could be useful. If I knew people nearby, I'd be willing to share my lifetime supply of DE for example. (or better yet, I could've borrowed someone else's!)
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Jan 2012
    'burbs of Augusta, Georgia
    7,286
    Re: Member Map
    Another idea you can try is to go the the drop down list called "Community" and go to the "Members List". Then up in the top right hand side put in "West Bloomfield, MI" and it will bring up posts by anyone listing that in their profile. You might see folks posts and consider private messaging them to make contact.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Member Map
    I kinda like the idea of a map. Even if it was anonymous. Just would be interesting to see.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Member Map
    Quote Originally Posted by pabeader View Post
    I'm not a web programmer but I assume there are apps, templates or plugins that would take zip/postal codes(if members supply) and place pins/dots on a map?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    May 2016
    West Bloomfield, MI
    709
    Re: Member Map
    Yes - pins on a map: we've used several on other forums. A SeaRay boats forum has used zeemaps. I'd post a link, but it's only accessible to members.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Member Map
    Google maps has a fairly easy way to do this from a CSV file of zip codes.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Member Map
    I do not believe we ask for or capture zip codes. And for some reason many members put their city but not their state in the location field. But, that is just a text field anyway so stripping the info isn't possible. Especially since people often put something like DFW, TX. The only purpose of the location is so we know what climate your pool is in so we can offer better advice on things that are impacted by climate.
    May 2016
    West Bloomfield, MI
    709
    Re: Member Map
    A benefit of having members manually add pins is that we'd get the active members who want to be on the map.
    Quote Originally Posted by pooldv View Post
    I've wondered if the Dallas / Ft Worth area is the only one that's identified by residents using the airport code. I have referred to Fort Lauderdale as FTL, but then they changed the code to FLL...
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Re: Member Map
    While it is an option to allow this it's something I'd have to greatly look into before doing. This option is not available "out of the box" from vBulletin however there are various modifications that alter the forum code to add this feature. While not uncommon to use these modifications (TFP uses about 10) these are something we tend to avoid as they can cause various errors to the software. In addition as TFP grows and updates its site these modifications too will need to be updated. This is something that frequently isn't an option without custom codes being written.
    May 2016
    West Bloomfield, MI
    709
    Re: Member Map
    the google and zeemap options aren't integrated, but just links to external resources.
