Thread: How to keep the heat in the pool. Trying to get an extra week or two of swimming.
    May 2016
    Walkertown, NC
    28
    What is the best way to retain / add heat to my pool. I have a blue solar cover.
    Keep covered unless using pool?
    Does the pool heat up more when ambient temp is above pool temp with cover on or off?
    keep pump on low 24 hrs per day or run high speed part of the day?
    If later which part of the day?
    24' AG Round 12,700 Gallon ( w/ 45" level) Vinyl Liner
    Pentair Sand Dollar SD-40 Sand Filter w/ 1.5 HP 2 Speed Pump
    Taylor K-2006 Test Kit
    Walkertown NC ( North Central NC 30 miles from Greensboro, NC)
    Pool gets 6-7 hours of sun on a sunny day
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,833
    Re: How to keep the heat in the pool. Trying to get an extra week or two of swimming
    I would suggest keeping the cover on at all times unless you are swimming and only run the pump when the sun is shining on the pool. Running the pump at night/cooler parts of the day will increase your heat loss.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jul 2015
    Central Valley CA
    1,109
    I too have a blue cover and it seems I get a little more heat with the blanket off when the pool is in direct sun as long as there is no wind. We have a dark surface that may help a bit too. When this cover dies I plan on getting a clear one.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2016
    Walkertown, NC
    28
    Thanks guys
