Results 1 to 7 of 7
Thread: Free chlorine climbing daily after cleaning Turbo Cell
    Jun 2016
    Goshen CT
    21
    (apologies for posting this in pool chemistry as well....please advise where it is appropriate)
    Hello all-
    This weekend, I decided to start taking care of the pool myself. First order of business was to clean my Hayward Turbo Cell. Bam. Done. Chlorine is getting produced. I had put it on SuperChlorinate for 24 hours after cleaning on Saturday and then switched it back to Auto.
    My FC levels have been rising ever since.
    Saturday 3.0
    Sunday PM 6.2
    Monday AM 8.5
    I'm not sure what my next step should be. Turning off the SWG until I get to a good place?
    Full test results:
    FC: 8.5
    CC: 0.@
    PH: 7.5
    TA: 90
    Hardness: 180
    CYA: 0 (i just put in 2 sock fulls of Stabilizer last night in the skimmer)
    Western New England Outdoor 1980s Vinyl lined SWG 24,000 gal. rectangle 40' x 20' x 4'
    Hayward AquaRite w/ T Cell 15 Pentair Superflo VS Hayward 406a Propane Heater
    Pool Testing: Taylor K-2006 and Taylor Saline testing kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    Re: Free chlorine climbing daily after cleaning Turbo Cell
    I'd say do nothing as with that zero CYA your FC will lower itself in one good sunny day. Keep it off "super chlorinate" mode and just set it to what you think you need to run it at, and then just keep monitoring the tests to see what happens. You'll tweak the pump run times and the SWG % to maintain your FC where you desire it.
    How much CYA did you add? How much were you striving to get your CYA up to?
    If ever you need an instant boost in FC, just use bleach. Its faster and less wear and tear on the SWG.
    Jun 2016
    Goshen CT
    21
    Hey there. Thanks for responding. I added 4 lbs. don't really have a goal but i had zero. Will pick some more up today. I haven't really learned to manage chlorine production with the pump. The pool company had taken care of everything. I guess that's next -- perhaps having the pump run on low for a while.
    But since my CYA was zero yesterday, why did my FC go up? It has been super hot and sunny.
    Jan 2012
    7,273
    How are you testing? could it have been testing error?
    Jun 2016
    Goshen CT
    21
    Taylor K2006. I'm pretty diligent about it since i started.
    Jan 2012
    7,273
    Ok, well, I don't have an explanation but at least its gone up and not down! Yay! <--TFP's Kim rooting you on!
    So per PoolMath, 4# of CYA will bring you up to 20ppm (assuming you were truly at zero to start with). You will need more. How high are you planning on taking it considering your season is coming to a close soon, right? Will you be closing the pool down and covering it soon?
    For reference here is the cya/chlorine chart to guide you on where you keep your FC level based on x amount of CYA--> FC/CYA Chart
    Jun 2016
    Goshen CT
    21
    Quote Originally Posted by YippeeSkippy View Post
    Ill be closing the pool down in a month or so. Last week of September. Yup. I'm going to add some more this afternoon. Thanks!
