Results 1 to 10 of 10
Thread: Help Me Identify This White Hard Substance
    Question Help Me Identify This White Hard Substance
    Pool has about 740 ppm TDS. I thought it was mineral precipitation, but there are no "flakes" floating around throughout my pool
    PH is at about 7.5, TA is 80, Free Chlorine 3ppm. I have a Ecomatic SWG that they say runs better at higher salt levels (min 3000), and mine is at around 3700 ppm. Pool is about 4 years old and there is very little scaling on the pool tile. There is a faint amount and even muriatic acid wont take it off. Only telling this as I don't think this is typical mineral scale.
    This bright white (like stryofoam) substance is forming on the saltwater generator grids and ends up on the pool floor by the jets. I theorize it is breaking free and exiting through the jets. Not a ton of it, but maybe 4-5 pieces of this (see picture) are under the jets resting on the pool floor.
    Its hard, and thick (not like typical mineral scale). Somewhat porus. About the same hardness as a graham cracker and if you smash it around, it will turn into fine grains. If I keep smashing it in my fingers it will turn into a paste like consistency. I tasted it (just touched my tongue on it) and it was barely salty
    30,432
    Re: Help Me Identify This White Hard Substance
    put a drop of muriatic acid on it. If it fizzes, it is calcium scale......that's my bet.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    ^And let me know if it doesn't fizz...I have other tests you can do by grinding it up with mortal and pestle. The conditions inside a salt cell can cause just about any combo of carbonate scale, and IME, some don't fizz
    Do you use dry acid at all? Or just MA? If the sample doesn't fizz, post a complete set of water test results.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Yes, Acid will make it fizz.
    But why would it be forming predominantly on the salt cell and not other places in the pool?
    I thought scale was a lot "harder" in texture (like the scale on my pool tile which you can not mash up with your fingers"
    Is there a way to address this on the salt cell besides just cleaning it with an acid solution? Trying to determine the actual cause
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    PH is higher in the cell so scale forms more readily. There are different types of scale with different mineral make up. Maintain your CSI around -0.3 and see how it does. More here, Pool School - Calcium Scaling
    Add your pool info to your sig so that we can better help you. More here about what to put in your sig and how to do it, Pool School - Read This BEFORE You Post
    I added all my info in the signature.
    Calcium Hardness was just tested at Leslies (sometimes I question their accuracy) and it is 600 ppm. They said my TDS is over 5000 ppm but salt is throwing that off. CA is at 50 (it was at 80 about a month ago so I question the accuracy of this as well)
    22,000 gallon In Ground Pool. Remodeled in 2012. Pebbletech (light Grey). Pentair Clean & Clear Plus 520. Pentair Intelliflo Pump. Talor Test Kits. In Ground SPA elevated above pool. Ecomatic ESC-36 SWG. Water restriction in Orange County, CA and draw water from municipality (Golden State Water)
    Quote Originally Posted by Swampwoman View Post
    I use only liquid MA.
    Free Chlorine is 5
    Salt is 4500
    Calcium Hardness 600
    TA 70
    ph 7.6
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Do you still have the Taylor test kit listed in your signature? If so, which version is it?
    DFW, TX
    24,514
    We always question test results from the pool store. Do you have any test results?
    Quote Originally Posted by PAGirl View Post
    yes. It the Leslie branded one 18-571 is the number on there. I have an electronic Hatch salt meter that I calibrated in a 3000 ppm baseline solution. I do not have a CYA test nor do I have a hardness test. I have electronic TDS meters made by HM
