Results 1 to 16 of 16
Thread: New build in MA
    Jul 2015
    Melrose, MA
    6
    New build in MA
    Hello Everyone!
    My wife and I have decided that we we are going to start the process of putting in a pool but we are a little new to what is needed to get started. We are not tied to a design but we want a in-ground gunite. My question to you is where did you guys start, did you just start calling PB's? We are not sure of our property lines especially our back side as our house backs up to town land (woods), should we get it surveyed first or is this something the PB does? While we are on the subject of PB's does anyone have an suggestions on ones in MA. While searching many people don't mention who they are using. Anything helps, thank you.
    Geoff & Tara
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: New build in MA
    The more "wants" you can describe to your pool builder, the easier it will be for him/her to make it happen.
    Is the pool for lounging or actual swimming? Do you want to be able to dive (have it deep enough) or just a sports pool (a more shallow pool).
    How curvy and artistic do you want the shape.... or is simpler better to you?
    Do you want to invest in an autocover for safety? How about water features like fountains? Do you want a spa?
    I'd suggest looking on Pinterest and getting some ideas of pools. Also here you can look at folks pretty pools on TFP.
    Do you want to maintain the pool yourself (easy peasy really!) or have someone else do it? How do you want to sanitize your water? I would only suggest looking at SWGs or liquid chlorine, avoid Bacqau (ugh!) and avoid UV/Ozone devices.
    Jan 2016
    Mesa, Az
    541
    Re: New build in MA
    Get a survey FIRST. Identify any easements or setback requirements. Do you have an HOA? Where are your utilities? Once you have these answers you'll know what you CAN do. THEN it is a matter of choosing what you WANT to do.
    May 2015
    Land O Lakes, FL
    527
    Re: New build in MA
    I too would want to have a pretty good idea of the size / shape, etc that you are looking for before you talk to any builders. Otherwise, alot of time will be wasted and you will have larger variations in what the builders propose making it very difficult to compare. That also adds alot of time to the estimation process.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Re: New build in MA
    Echoing many thoughts above, and also adding a timeline component:
    I strongly encourage you to spend a few months researching all sorts of pool related details (here, elsewhere online, from people you know who have or built pools, etc.) Feel free to use us as your consultant to bounce any and all ideas off of. It's a really good idea to have one source that you trust (TFP can be that) where you get feedback on the things you hear elsewhere. There will be numerous times you get conflicting information in your research and the folks here have been there and done that - and are willing and able to assist.
    Regarding a project timeline, I'd get deep into research now, including researching PB's (without contacting PB's yet). Then by mid-October, schedule your onsite meeting with 3-5 PB's. Sign your contract by December and be on the beginning of their list for the spring. Some will likely want to start early (late winter). Then if all goes as planned, you'll be complete by the beginning of swim season (Memorial Day weekend). You may use a heater which might push that date forward in future years, but don't plan on it the first spring because you have to wait 30 days after plaster to use it anyway.
    Regarding a method to organize your research, I'd create a system (Excel file, notebook, whatever) to segregate the data into the following areas (which I'm not wedded to):
    • Aesthetic / Design Likes & Dislikes
    • Construction Details
    • Site Details
    • Pool Builders
    • Financing
    Under each of those you will have 5-10-20-100, who knows how many, questions/sub-topics to think about. And then you will also add links, thoughts, other peoples comments, topics to address in each section.
    Then when you meet with each PB, you will have a comprehensive list of details to go over with each one that has been narrowed down. How you present that to the PB's is personal. I chose to create a several page list of project specifications for them to bid on. Some adhered to it very tightly, others veered some, mostly on equipment which was ok. That process helped me to get much more comparable bids from the PB's. This process doesn't work so well for those either not willing to put in the time up front or who have no idea what kind of pool they want until the PB's make suggestions.
    Best of luck and ask away. We find it best if you ask all of your questions in one thread (this thread) so that anyone answering who wants details on previous discussions, can easily find them. Some do start separate threads on things but I generally don't find that the best way since building a pool is million interconnected issues, not one-off question/answers.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2013
    New Hampshire
    351
    Re: New build in MA
    We had Family Pools out of Lawrence do ours and they couldn't have been better to work with. They still do the opening/closing etc and have nothing but good things to say about them. They came recommended to me by one of my clients.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Jul 2015
    Melrose, MA
    6
    Re: New build in MA
    Quick Update - I wanted to post a picture of the backyard and the wife and I keep having more and more discussions about the pool and what we want. We are noticing that there are a lot more options out there for lined pools than there you used to be. We each had pools growing up, I had a gilbraltor above ground pool and she had a gunite. We were originally going to go with a gunite pool but looking at the different options of lined pools and the price we are now looking at those as well. We don't like the look of the white plastic stairs so it would have to be a steel step lined pool.
    Another note we found a surveyor and will start that process today. I also talked to the town today (Melrose, MA) and it seems we will have a few more obstacles than most as we have a shallow backyard. Its 80 feet wide but not very deep. We will need to get a variance to get the size we want (more than 10ft). In the picture I believe we only own up to the edge of the grass, according to the plot document we have now anything past the grass going to the rock wall is conservation land owned by the town.
    More to follow...
    Mar 2013
    New Hampshire
    351
    Re: New build in MA
    I agree with your non white stair comment. Here is mine:Attachment 53956
    May 2013
    Needham, MA
    140
    Re: New build in MA
    We just completed our pool build in Needham. We used Pools by Andrews and could not be happier with how it came out. Similar to you we have a narrow depth on our lot. Needham is very strict and would not allow any variances. We had the as built survey done first with a pool envelope drawn on it so we knew where we could build. I then met with 5 local builders giving them each a copy of the survey prior to our meeting. This way they were able to have ideas in mind prior to our meeting. We went with a liner pool. We did not care for the look of the white fiberglass steps so we went with the liner over steps. Andrews included in the contract paver coping. Our pool looks stunning! Does not look cheap at all, which some people think liners can be. Here a link to my construction thread. I need to add the completed pics, but close enough. PM me if you have any questions.
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    Jul 2015
    Melrose, MA
    6
    Re: New build in MA
    Rmclain - those are the type we would like to see if we went with the loner option. Thank ou for the post.
    We are more and more interested in the vinyl liner route as it may give us more of a budget to put in a fire pit, nicer patio and maybe a cabana of some sort.
    On a different topic can you have tile installed just above a liner? We don't necessarily like the option of fake tile that comes with the liner.
    Sparker's Avatar
    Jun 2016
    Indiana
    128
    Re: New build in MA
    I'm also starting my pool build. I chose to get a borderless liner (floor pattern all the way up) I didn't want the tile look either. I've read on here, that some people think it makes the pool appear larger. I'm not sure if you can add real tile above. Congrats on your decision to build a pool!
    Quote Originally Posted by Gpope View Post
    15x30 rectangle vinyl IG, Sta-Rite Cristal-Flo II 19" sand filter, Sta-Rite Super Max .75 HP 2 speed, 1 skimmer, 3 returns, 2 bench jets, 2" plumbing, TF-100 kit, Latham Gold Pebble liner. Dolphin Active 10 robot.
    Jul 2015
    Melrose, MA
    6
    Re: New build in MA
    Quote Originally Posted by doobs41378 View Post
    This is the color we are looking for as well, we are hoping you can get a border less liner in that color. I have seen that your experience with your PB was a good one, did you really do it for 18K?
    Mar 2013
    New Hampshire
    351
    Re: New build in MA
    18k is how many gallons the pool is. Not the cost that being said I would have no issues going over that I paid for it via PM. Yes, Family Pools was/is great to work with. I actually recommended them to another person that was from here and he was happy as well.
    May 2016
    Northeast MA
    133
    Re: New build in MA
    We also have a signed contract and deposit with Family Pools. We are scheduled for their first install in the spring once the ground thaws. My parents got their pool from them in the house I grew up in and never had any issues. Know a few others that have used them and all been happy.
    Inground vinyl 23'x40' Aspen shape, ~27K gallons, Sta-Rite Intellipro 2 VST Pump, Sta-Rite System:3 Mod DE Filter (60 sq ft), Hybrid In-Floor System (Paramount Valve with Caretaker Heads), AquaComfort Heat Pump, 3x Savi Melody Sol 28W LED Lights, Pentair IC60 SWCG, EasyTouch Automation with ScreenLogic, TF-100 test kit.
    Jul 2015
    Melrose, MA
    6
    Re: New build in MA
    So, things are moving quicker than I expected. I went and called one PB to see when I should be reaching out to get things started for next year and he said NOW! I told him I still don't have the survey and he didn't have an issue with starting the conversation. So with all that said, what do I need to have thought through for the initial meeting? The idea is to have a back yard that we can call our own oasis and be happy at every day in the summer and winter. Current requirements...
    Liner Vs. Gunite (not 100% sure)
    Spa
    Firepit (Gas or Otherwise, might be a town issue with gas)
    Heater
    If liner
    no white steps or ladders
    border less liner
    Black granite liner (or similar)
    glass tile above liner
    paver or concrete around pool (something that doesn't get hot)
    Fence
    2-3 LED lights
    Shed or similar to house pool equipment
    Equipment???
    This is all I have for now, I only have 2 PB's in mind so I wouldn't mind hearing other suggestions in the MA area if anyone has them. PM me if you dont feel comfortable saying their name. Anything I am missing?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    New build in MA
    I mentioned above a pretty detailed way to approach the process, with some thoughtful input. I didn't note a reply. I would pull up many of the new construction threads and look at the detailed quotes. You want to understand and be able to talk about each line item in those and how they apply to your build. In those threads you'll see many comments about topics to discuss with PB's. Then work those into my approach is my suggestion. I think you may have jumped the gun a bit on the process for the most efficient way to handle the task.
    Choosing a liner is not a front line decision.
    Liner vs gunite is a crucial decision that needs to be made first as it will lead you down one path of issues/questions versus a different path of them.
