Results 1 to 8 of 8
Thread: Can't get any bromine established in my spa
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    After draining and refilling my spa, I can't seem to get any bromine to register. I've added sodium bromide, an oxidizer (shock) and it's had a brominator floater running wide open in there for more than a week.
    Still zip on bromine. I am using test strips because my kit hasn't arrived yet, but I've had my local pool shop confirm. 0.0 total bromine.
    PH and alkalinity was little low and they had me add 6oz of baking soda.
    (one side note, my heater is not working and scheduled for repair this week, water temp is about 90 degrees and obviously no one has been in the spa since it was drained)
    What could be causing this? Could it be related to my bad heater?
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Can't get any bromine established in my spa
    Nov 2015
    VT
    84
    The only thing I can imagine is a huge load of contaminate (biofilm in your plumbing/filters?) that is using all your sanitizer.
    I would do a thorough cleaning using Ahh-Some, then drain/refill again. (I have no affiliation with that company)
    Hot Springs Sovereign (1999?)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    Yes, I've read that post and I feel like I'm following its instructions.
    I guess I did leave out an important piece of the puzzle where my hot tub did sit idle for a several days after I refilled it because the heater was causing the GFCI to trip. Took me several days to figure that out so even though no bathers entered the spa, contaminants could've been building during that time period and now I'm fighting them off.
    After continuing to add shock, I did see my test strips slightly begin to indicate bromine last night so maybe I'm finally catching it back up.
    Memphis, TN.
    Taylor K-2006
    Nov 2015
    VT
    84
    I think I would still start fresh after a good cleaning (including Ahh-Some for biofilm).
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    Quote Originally Posted by Brian VT View Post
    Good idea. Would I put Ahh Some in my current water and then drain and fill fresh?
    Memphis, TN.
    Taylor K-2006
    Nov 2015
    VT
    84
    I would.
    The Ahh-Some will create foam on the surface of your water. If the foam has some brown in it you will smile and be glad that you used it. If no brown is seen you will still enjoy the peace of mind from knowing that your spa is "sterile" and safe to use.
