Thread: Should I raise my TA?
    Apr 2016
    Youngsville, LA
    274
    I have a 15k in ground plaster SWG pool. My TA is currently at 40, should I raise it and if so how much? Looking through the table of contents, the recommended range is 60-80, should I try 60 first? Will a low TA cause my pH to rise at a faster rate than normal?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,755
    Re: Should I raise my TA?
    A low TA will limit your pH rise. A higher TA will make the pH rise faster and higher.
    Can you post a full set of test results?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    An SWG tends to push PH up. A high TA can encourage PH rise. Too low of a TA can bottom out the PH. What has your PH been testing at lately?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I would raise TA to 50 and answer the questions above.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My suggestion is to monitor your pH over a period of time and note if it is rising, if it is then don't raise your TA
