Thread: Pool Rake and/or Vacuum
    Mar 2016
    Houston, TX
    27
    I keep getting leaves settling in the bottom of my hot tub. Any suggestions?
    I was considering getting a leaf rake or vacuum.
    Bill
    The Woodlands, TX
    in-ground plaster pool, hot tub overflow to pool (16,000 gallons), 48 sq ft Nautilus FNS DE filter, gas heater, dual main drains pool & hot tub, chlorine source bleach (10%) & trichlor tablets 2-3 times/yr, Taylor K-2006 kit, 55-60 gallons per minute flow
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Pool Rake and/or Vacuum
    PoolBlaster Max... a nice rechargeable hand/pole vac that works well for us.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    +1 on the pool blaster max....I bought mine last october and it has worked quite well, although recently it
    stopped taking a charge but it's within warranty replacement period. If I bought another I would buy
    an extended warranty if it's offered (if you buy it on amazon)
    Dolphin E10 Cleaning Robot.
