Results 1 to 7 of 7
Thread: White buildup
    Aug 2016
    Skipwith
    19
    White buildup
    Hey everyone,
    I recently bought a used intex ultra frame pool. It was only owned for a month before I got it. When I set it up, there was a decent size white stain or buildup in the center of the pool. I assumed it would go away with good water, But it's still there. It is sorta rough. What could it be and how would I go about getting rid of it?
    20'x48" intex ultra frame
    Original pump and filter setup (will replace in 2017)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: White buildup
    Sounds like it is scale. Are you maintaining your ph below 7.8? More here, Pool School - Calcium Scaling
    Aug 2016
    Skipwith
    19
    Re: White buildup
    My ph is low right now.. ive been slowly adding borax to raise it..
    Jul 2016
    Noblesville, IN
    30
    Re: White buildup
    Is it possible that it is just bleached from the previous owners chlorine?
    Pete and Family
    Graduated from baby wading pool to Quick Set Intex 10 ft to Intex steel frame 12 ft over the last 5+ years
    Just purchased BestWay 22 ft x 52 in on clearance - will graduate to it next spring!
    Aug 2016
    Skipwith
    19
    Re: White buildup
    It may be. Ill try to message them.
    Is it able to come out of the liner if it is bleached?
    Aug 2016
    Skipwith
    19
    Re: White buildup
    I talked with the lady who previously owned it... apparently it's chlorine.. they had some kind of chlorine ball and it sat on the pool floor..
    Is there a way to get rid of it?
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    832
    Re: White buildup
    Nope. Bleaching is irreversible. I have some bleaching on mine, but it has been there a couple of years so I don't worry about it. (Happened pre-TFP!)
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
