Thread: New pool
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    New pool
    Hi guys, I just got my new pool turned over to me from the replastering , I did my first check and the PH was 8.4 . Am I right is assuming that I should get the PH stable before adding of the other chemicals?
    I do not want to ruin my new plaster .
    I am working with fresh water now, I will convert it Salt when I get the fresh water stable
    Walt Lukowski
    Southern California
    Salt water pool at 24000 gal. new whisperflo variable speed pump. 60 gal. per min.
    30,403
    Re: New pool
    Yes, do what it takes to keep your pH in the 7's.
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Re: New pool
    Thanks for the quick reply, I am having the wife get 4 gal of acid the calculator says to add 823 oz
    Walt Lukowski
    Southern California
    Re: New pool
    Quote Originally Posted by wbrewski View Post
    Add half the amount of acid you are being told to add, then re-test.
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Re: New pool
    Thanks guys.
    have a good day
    Walt Lukowski
    Southern California
    Feb 2015
    Chandler AZ
    925
    Re: New pool
    823oz of acid?? That sounds like WAY TOO MUCH acid to add to a 24,000 gallon pool.
    Is that a typo?
    What calculator are you using?
    What is the percentage of the acid you are using?
    What pH level are you attempting to shoot for?
    What is your TA?
    If you think you're at pH of 8.4 - with pump running, add enough to get to 7.8 and retest in 30 minutes. Keep adding until you get to 7.8 - as you could be above 8.4 to start with. After you are stable at 7.8, lower the pH to your desired level. Leave pump running while adjusting levels.
    Please post a full set of test results.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
