Results 1 to 11 of 11
Thread: Murky water
    Murky water
    Hi everyone,
    I hope the final days of summer treat you well.
    I'm 3 weeks past SLAMing my pool and the water is becoming murky.
    I've been testing regularly and mainly focusing on keeping FC @ 5.
    These are today's test results:
    FC=4.5
    PH = 8
    CYA = 30
    AL=130
    I havent backwashed in 2 weeks and just did a backwash and rinse cycle.
    Can you please advise on how to get it back quickly?
    T
    13,000 Gal (Est.) 14x28 pool w liner
    Hayward salt system - Aqua rite low salt
    Hayward Pro Series Filter
    30,432
    Re: Murky water
    If your filter is clean, lower the pH to 7.4 or so and SLAM your pool.
    Brush as much as you can, vacuum as much as you can, keep the filter clean.
    That should do it.
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Re: Murky water
    That should do it.
    +1
    How often do you brush and vacuum?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Re: Murky water
    I'm brushing every 3 days and vacuuming once a week.
    Aug 2014
    Northern IL
    4,615
    Re: Murky water
    Did you decide to do a slam? Did your FC ever drop below 4ppm?
    Re: Murky water
    Im SLAMing right now.
    FC = 14.5 (taking it to 16)
    PH = 7.6
    Its turned grey / blue so will do the test tonight.
    Re: Murky water
    Before this, my FC was as low as 4 only and I was moving it to 5 each time. Its been really hot here so I'm guessing the heat played a part.
    Aug 2014
    Northern IL
    4,615
    Re: Murky water
    No need to test your pH during a slam, btw. You might not be ready for the OCLT, but if you get up early anyway, no harm!
    Re: Murky water
    Pool is now crystal clear. Thanks for all your help.
    Aug 2014
    Northern IL
    4,615
    Re: Murky water
    Excellent!!!! Did you do an OCLT to check everything?
    Re: Murky water
    yes, the fc level didnt drop and pool was clear.
