Results 1 to 7 of 7
Thread: Air bubbles coming from pool return
    Jun 2016
    Manchester, United Kingdom
    41
    Hi everyone
    I've just noticed a strange problem after returning from holiday.
    There is an awful lot of tiny air bubbles coming into the pool via the return.
    I've not seen any visible leaks between the pump and the pool so my only guess is there is a leaking pipe underground.
    Does anyone know how to isolate / fix this issue?
    Here's a video showing the problem.
    Thanks
    Joe
    https://vimeo.com/180498104
    26500 Litre (6000 imp gallon) Above ground vinyl pool. Manufactured by GRE (Spain). 10 years old this year.
    Sand filter. Single speed pump. Elecro 9kW heater.
    Test using a TF 100 kit and AquaChek strips if desperate!
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: Air bubbles coming from pool return
    Is this while you have your manual vacuum hose hooked up?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Jun 2016
    41
    No it's constant. I just happened to be vacuuming the pool when I took the video.
    Thanks
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Oh ok.
    Installed May 2011
    BBB method
    Aug 2014
    Northern IL
    4,615
    Did you check the gauge on your filter? Maybe you need a backwash.
    Jun 2016
    41
    Yeah all back washed and pressure is normal.
    30,421
    You have a suction side air leak. Their is an article in pool school that will be helpful.
