Thread: 26x52 above ground Intex Pool
    Aug 2016
    Dallas, TX
    1
    Just purchased and added Saltwater System how do I start-up and what and how much chemicals do I need!
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: 26x52 above ground Intex Pool
    Hi and welcome
    First off we need to know what you have so we can help you learn what you need. Can you please fill out your signature so we know your pool details. http://www.troublefreepool.com/conte...efore-you-post
    We always recommend a good test kit, its the basis of what we practise which is to test the water regularly, add only what you need using chemicals with the least side effects to make keeping a pool cheap and easy. Both of these kits are only available online http://www.troublefreepool.com/conte...its-comparison
    I would suggest in the meantime you add liquid chlorine or bleach to keep your chlorine levels up. As for how much its hard to tell without testing to know where you are at but i would add about 100oz of 8.25% bleach daily till your kit gets here and we get reliable test results
    You may also want to get some muriatic acid to lower your ph. You may need stabiliser but only if you have not added any solid forms of chlorine to your pool.
    This article is very helpful: TFPC for Beginners
    This tells us what chemicals to add when: Pool School - PoolMath
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
