Results 1 to 8 of 8
Thread: Took over my pool maintenance from the Dreaded Pool Guy!
    James&Sila's Avatar
    Aug 2016
    Riverside, CA
    6
    Hi guys,
    New to the site. I'm grateful for what I have read and learned thus far from the "Pool School." I've ordered the TF100 to be in this week. I've since had the water completely exchanged with a R/O Treatment and getting the water back to balance. I had the local pool store run a water test to see where I am. Everything was off, obviously when started after the water exchange. Here is where I am now:
    FC- 5 (Just added everyday the last 3 days to get up to level, it was 0)
    pH- 7.5
    TA- 70 (I added product to raise 30ppm in pool a few minutes ago)
    CH- 110
    CYA- 32
    TDS went from >2500 to now 400
    No metals/phosphates in water
    I am happy to start fresh now with new equipment. Biggest question is where to buy product. I will be using liquid chlorine once I use up my leftover 99% Dichloro and 73% Cal Hypo, I do have a jug of muriatic acid left. What else is needed and where to buy.
    Thanks for all the knowledge!
    18'x32' IG approximately 25,000 Gallon Plaster Pool, Jacuzzi VS Pump (1.5 hP), Purex SMBW2048 D.E. Filter (47 sq. ft.), 1 Skimmer, 1 Return, 1 Main Drain, "The Pool Cleaner 4X" Hayward Poolvergnuegen Cleaner. TF-100 w/ Speed Stir, SoCal Water Restrictions.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Re: Took over my pool maintenance from the Dreaded Pool Guy!
    Welcome to TFP! Now that you have the tools to properly maintain your pool it will be the envy of your neighborhood. Wal-Mart, Lowes, Home Depot, Ace Hardware (or any other well stocked hardware) as well as grocery stores should have 95% of all you will need. Either the pool section or paint section of the big box stores can fulfill your requirements. Be careful of the materials that you mentioned, now that your water is getting to great shape, don't overdo it.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    More here on pool chems, Pool School - Recommended Pool Chemicals
    I buy bleach at Kroger. Store brand concentrated, 8.25%, unscented, not splashless and not easy pour. I buy CYA/stabilizer and muriatic acid at Lowes. The rest also comes from the grocery store.
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    How much leftover stuff do you have? You might want to rethink using it and save it for a later time when you need to bump cya or chlorinate another way while gone for a few days. I'm sure you have read that your dichlor will add CYA, you are nearly in the correct range now if the pool store tests are even close. I would not use a lot more dichlor until you know for sure. Pool store tests are often so far off they are worthless. With a plaster pool to be concerned about, the cal-hypo will add calcium that you may not need either.
    Once you get your kit you can run your own tests and know for certain, then decide whether to use it or not. No sense getting too much in there now as it would require another RO treatment or water change to fix these problems. No time like the present to just start using bleach, the chemicals you have will keep for a very long time. I have tablets that are ten years old, they still work fine and still add loads of CYA with each dose.
    Many folks here just use great value bleach from WalMart, just plain simple bleach, don't get bleach with any extra stuff in it. I have found the stronger stuff (10-12.5%) sold as chlorinating liquid or liquid pool shock is often cheaper than bleach. It's a promotional item in the spring and placed on clearance later in the summer so deals can be found. Bleach just stays about the same price. The pool stuff gets hard to find here later in the season, might be different in your area.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    30,432
    dsmith99 offers very good advice. That dichlor puts back 7 ppm of CYA for every 10 ppm of chlorine. I hate that stuff for that reason. Use it carelessly and your CYA will make your pool unmanageable. Cal Hypo adds CH to your pool. It can build too high rather quickly, too.
    Last, we have learned over the years that pool store testing is very wrong most of the time. Please report your tests from the TF-100. We trust that testkit and we trust you doing the testing far more than any pool store.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    At the end of an RO treatment your CYA should have been "0". If the testing is anywhere near close then you have already added 32ppm back. How? As Dave points out DiChlor leaves huge amounts of CYA in the water.
    Until you get your test kit and can verify the CYA and control additions please stick with liquid chlorine for now.
    Support the site
    James&Sila's Avatar
    Aug 2016
    Riverside, CA
    6
    Thank you all for feedback! To answer some of those questions, I only have a few packs of the cal hypo and a few of the dichlor. I won't be using the dichlor up anytime soon. The cal hypo- I may as my calcium hardness is way low to TFP settings of 220-350. I was at 110-120 so I know that is off. I will verify the CYA, but conditioner was added by the R/O team to rebalance after the treatment, thus is why it is on the low end of the acceptable range 30-50.
    Since speaking, I found some material at Lowe's pretty cheap- Summer discounts and was able to pick up a few things including Liquid Chlorine. 2 gallons in a box. Now with that being said it shows 10% Sodium Hypochlorite and 90% other ingredients. Main chemical of Bleach. This should work right guys? Thanks again, the test Kit should be in this week and will keep you posted!
    Thanks!
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Can you check the production date on that bleach from Lowes? I usually tell folks to avoid Lowes for liquid chlorine/bleach as they don't have a high turn over and they tend to store it outside in the sun and heat. That degrades it so you may be paying for low quality chlorine at this stage of the summer.
