Thread: Should I Replace the Return Jet Faceplate?
    Apr 2015
    South Central PA
    298
    I have a return jet faceplate with a 4 hole screw pattern. Each hole has a crack from the hole to the edge of the faceplate. Should I replace this or just leave it alone? It is not leaking, but I don't know at what point it would start to leak. I don't know if this is one of those things where you disturb it and that causes it to start leaking.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Jun 2014
    15,298
    Re: Should I Replace the Return Jet Faceplate?
    Not sure about your particular faceplate, but many of them are simply a cosmetic cover or designed to keep the return pipe stable in the hole. The return's true seal is often times behind the faceplate which is why many pool owners can remove the faceplate and modify their return fittings if needed. Since it's not leaking, I'd be more apt to just leave it alone. Keep-on swimming right past it.
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    I'm with Texas splash... Keep on swimming ����
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
