Thread: New pool. Help!
    Jul 2016
    Prosperity, SC
    23
    New pool. Help!
    Brand new salt water vinyl liner pool. It is 19,000 gallons. I am waiting on my real test kit but could use some advice on where to start now until it arrives. I work out of town so I need to do whatever tomorrow before I leave. Here are my reading off of a strip test. Total hardness is very low, total chlorine is at 20, free chlorine is at 5, pH is 6.2, total alkalinity is 0, cyanuric acid is 0. What do we need to do to get the water right? Thanks!
    18,500 gallon vinyl lined pool, Intellichlor IC40 SWG, EasyTouch 8 Control Panel, Pentair SF-N1 pump, Pentair Sand Dollar SD80 Filter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: New pool. Help!
    Those test strips are wasting your time. Those numbers don't even make sense. Wait for a good kit. Doing anything with those numbers will just make it worse.
    Read some pool school.
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
    Jul 2016
    Prosperity, SC
    23
    Re: New pool. Help!
    Contractor filled my pool from a large lake in sc. Just put salt in today if that helps any. I was just thinking I should at least get pH right before I go out of town Monday
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: New pool. Help!
    Yes I agree you need to get your ph right. Walmart has a small hth drop kit that tests ph that is used for seasonal pools if you dont want to wait and is considered reliable for all tests. A pool store may have a ph only test for cheap
    You can manage the ph from test strips, kinda. I found they were pretty close when in the range of the ph printed on the kit, but once outside of that range all tests were unreliable
    This is not what I would call a recomended process and normally I would say wait on your test kit
    If you use the test strips to adjust ph I would add half of what poolmath calls for, test in half an hour, add again and adjust slowly to get in the acceptable range. You may get big swings as we dont know what your TA is.
    I would not rely on the test strips for any other parameters
    You use muriatic acid to lower ph,
    To raise ph either 20 Mule TeamŪ Borax Natural Laundry Booster or ARM & HAMMERŪ Super Washing Soda Detergent Booster
    Poolmath is at the top of the page to calculate what you need
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
