Thread: Heater problem
    Aug 2016
    Harlingen / Texas
    3
    Heater problem
    I have a Sta - rite SR 400 HD that I bought six months ago, the heater start ( the blower) then the burner comes on for few seconds and turn off it does the same few times the heater turns off and the service the heater light comes on.
    Any thoughts as to the problem/
    Thanks
    Jun 2012
    western NY
    1,559
    Re: Heater problem
    maybe flame sensor
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Aug 2016
    Harlingen / Texas
    3
    Re: Heater problem
    I that the stak flue sensor?
    Thanks
    Jun 2012
    western NY
    1,559
    Re: Heater problem
    No. in the burner chamber there is either a separate flame sensor or it is part of the igniter. I did not look up the schematics for this unit so i am not sure which it will be.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Heater problem
    The ignitor is the flame sensor on this unit. Are you getting an error code when it shuts off?
    If it is 6 months old, did you buy it and have it professionally installed? It should be under warranty if new.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2016
    Harlingen / Texas
    3
    Re: Heater problem
    Quote Originally Posted by ps0303 View Post
    No when it shut off, but on re start shows r 13
    I bought it on the internet and had it professionally installed, but the installer doesn't appear to know what is wrong??
    Tks.
