Results 1 to 9 of 9
Thread: Pentair Intelliflo VF Clock Backup Battery?
    Jun 2016
    St Pete, FL
    7
    Question Pentair Intelliflo VF Clock Backup Battery?
    My Intelliflo's clock resets to midnight if the power is disabled for more than a few seconds.
    Pentair customer service confirmed it should retain the time for 96 hours, and stated that if it wasn't, something was wrong with "the capacitor that holds the time." The only thing that could fix this is "replacing the drive," which they didn't recommend because "it's as expensive as the whole pump."
    They couldn't tell me if the capacitor was field replaceable (I assumed there was a watch battery on the board--apparently not.)
    Has anyone else experience this or found a solution (short of replacing the whole pump)?
    Jon
    St. Petersburg, FL
    13k IG PebbleTec; Pentair Intelliflo VS VF 11012; Sta-rite Posi-Clear PXC95; CompuPool SWG; Hayward Navigator
    Jun 2016
    Oklahoma City, OK
    49
    Re: Pentair Intelliflo VF Clock Backup Battery?
    The only way pentair will "provide" a new drive unit replacement is via warranty. There's really no user serviceable parts inside the drive unit as it is supposed to be hermetically sealed from factory to end of life. You could though find replacements via resellers, the model numbers would need to match though. How old is your pump? Pentair covers these pumps with a 3 year warranty if professionally installed
    Mar 2015
    Sugar Land , TX
    424
    "supposed to be hermetically sealed"
    There was a TFP member who was able to get into the "supposed to be hermetically sealed" board. Do some thread searching. I think he was able to dry out his board and if memory serves me , LOL, I think he replaced or was able to test parts on the board.
    I found this posted by JEFPETESN, HOPE IT HELPS
    jfpetesn is offline
    Re: LCD Screen on Pentair IntelliFlo gone bad
    Just wanted to put my 2 cents in on this subject: I purchased a used intelliflo VS on Craigslist "practically new" and "guaranteed" to work. Got it home and powered it up to check and guess what? Pump worked but no display! Called the guy back and he refused to do anything so I thought I was really screwed on this one. Been reading through the threads on this issue and thought I really didn't have anything to loose by taking the display apart and having a look around.
    I found that inside the drive unit there were no signs of moisture or corrosion. I took the display apart and noticed that the LCD screen is held against a row of spring contacts simply by the pressure of the display case front. When I first removed the display unit it rattled when I shook it. I lightly cleaned the contacts even though they looked clean. When I reassembled it I applied a very thin strip of foam weather strip across the top of the LCD display before I snapped the top cover back on. This kept the LCD display in firm contact with the spring contacts. Reassembled the drive unit and when I reconnected the pump everything worked like new.
    So I think the display issues others are experiencing are due to the LCD unit being loose and not making contact with the spring contacts. I do not think it is a corrosion issue. While I would not want to leave the display exposed to rain, it appeared to me that the drive unit is well sealed from the elements and it would be very difficult for moisture to enter it.
    Just my opinion and what I observed on the one I have.
    Jeff
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jun 2016
    Oklahoma City, OK
    49
    I stand corrected. Though do keep it dry
    Mar 2015
    Sugar Land , TX
    424
    Quote Originally Posted by pyrotiger View Post
    Sent from my SM-G925P using Tapatalk
    You are very correct, dry is the answer. Pentair should address this issue but we know how that goes.
    Jun 2016
    St Pete, FL
    7
    Thanks, everyone, for the feedback. I'll open her up this weekend and take a look around--will let you know what I find, if anything.
    St. Petersburg, FL
    Quote Originally Posted by Jon B View Post
    Did you resolve the issue?
    In ground plaster - 12,000 Gallons
    May 2011
    Long Grove, IL
    117
    I am in the same boat. Power went out last night but we have a standby generator that comes on about 30 seconds later but clock was reset to midnight when the generator came online so had to reset clock on pump.
    As an aside, whomever "designed" the user interface for the pump should be made to make changes for eternity in h@lll. None of the buttons make any sense, sometime needing to press back, sometimes, escape and sometime select but always seemingly a random choice.
    Regards,
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    Wonder if you ever opened it as have the same issue with the clock on mine.
    Francisco
