Thread: Cloudy pool after using Solar Cover (Salt/SWG content)?
    Jun 2015
    Southborough, MA
    29
    For the most part, all summer, my pool has been crystal clear (salt system) with well balanced water chemistry except on two occasions. After heavy weekend use, we used our solar cover as we weren't expecting to use it for a couple of days. I typically run the pump/SWG 10 hours per day.
    After I a couple of days, I removed the cover and the pool was very cloudy. On the days covered, temp was in the 90s (I'm in the NE). The pool is in direct sunlight all day.
    First time, I brought a water sample to a local Leslie's and they sold my Phosophate reducer (I know, big mistake,, I've since bought a Taylor kit) and I ran my pump for 48 hours straight. That actually worked.
    This past weekend, the same thing. I tested my levels with my Taylor kit and everything seems fine (Alk is a little high). Salt level is 3000-3100.
    I also put my SWG in "Superchlorinate" as per the manual. I didn't run it for the full 24 hours. I ran it for 12 as we plan to use it today. It seemed to help a little bit. I plan to keep the pump running for a few days and I did bump up the chlorination % on the SWG as well from 50%.
    My question is why would I get this condition after using the solar cover? Could it be that it's not chlorinating fast enough to conteract the effects of the cover and heat?
    Thoughts?
    Thanks in advance!
    16'x40' Viking Rectangular fiberglass pool (depth 3' 6" to 8' ; ~ 27,000 gallons); Hayward AquaRite salt system; Hayward cartridge filters and propane heaters
    Paramount Vantage In Floor Cleaning system with Buzztop Channel drain
    9' x 10' Viking Raised Spa with Spillover - (depth 3' 4")
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Cloudy pool after using Solar Cover (Salt/SWG content)?
    My FC climbs when the solar cover is on. It blocks UV rays and FC consumption drops. I had the cover on for the last week+ and my FC went from 8 to 20. It also got a bunch of pollen on it and dumped it in the pool everytime we took the cover off.
    Cloudy water is most often due to not enough chlorine and is bacteria or algae growing in the pool. We recommend an Overnight Chlorine Loss Test to see if something is growing in the pool. FC should be kept above minimum for your CYA at all times, FC/CYA Chart
    Jun 2015
    Southborough, MA
    29
    Quote Originally Posted by pooldv View Post
    Actually, according to that chart, my CYA might be low at ~30. My FC is approx 3 ppm.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    If you can post a complete set of test results with one of the recommended test kits that will also let us take a complete look at other possibilities.
    SWCG's cause pH to rise and depending on your CH level, that can cause calcium to precipitate clouding your water as an example.
    But algae is always the first and most likely culprit as DV is addressing.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    The UV rays from the sun help break down and eliminate the CC in your water. This may be part of your problem. When its cloudy, does it smell like chlorine too? If so, that's CC. You should probably do a quick SLAM just to kill off any possible algae that you're barely holding at bay now.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
