Thread: Just finished AA stain treatment
    May 2009
    Dothan AL
    12
    Finished AA stain treatment a week ago. Working to get the numbers right for the long run. Amazing how good the pool looked after the treatment. Here are my morning numbers. The FC is starting to hold now for 2 days.
    FC 5.5
    PH 7.5
    CC 0
    CYA 80
    TA 90
    CH 380
    Salt 3200
    Temp 85
    I may have over done the CH. I've noticed a post that recommends 250-350. Should this be a problem and should I shoot for a lower PH. The water didn't feel real good yesterday and is a bit cloudy.
    2013 In ground 32 x 16 Gunite 18,000 gal
    Hayward Aqua Plus Polaris 280
    2HP Hayward Super Pump
    Hayward 6060 Booster Pump
    Hayward S244T Sand filter
    30,432
    Re: Just finished AA stain treatment
    CH is fine at 380. Test your refill water and see how much CH you are adding when you refill.
    Did you add CH to your pool?
    May 2009
    Dothan AL
    12
    Yes I did and I think I over did it. I'm working on getting the pool volume down pat. I originally thought 21000 with calculations but should probably use less. Possibly 18,000. I'm going to redo it today and do sections. The CH had dropped to 200 and I had not watched it. So making a big change caused me to go over. I know better too! Also never having a sand filter before I thought I didn't have to back wash except maybe once a year. Well, that was totally wrong also. The muck that came out was dreadful....... I've since backwashed twice now, once since the AA treatment and still had lots of green in the filter. So after this am backwash I hope the sand problem will be fixed and my water will sparkle again soon.
