Results 1 to 7 of 7
Thread: Lowering TA
    Jun 2016
    Manteo north carolina
    50
    Lowering TA
    All summer long I have been trying to lower my TA to 70. Using the TFP method with muractic acid. Last week my TA was 110 ph 8.2 added acid to lower ph to 7.2. This week TA is 120 and ph is 7.8. Is it normal for the TA to keep rising like ph does?
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,081
    Re: Lowering TA
    How are you getting a TA of 132?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    30,426
    Re: Lowering TA
    Like Mr. Bruce, tell us how you got those results.
    No. It is not normal for TA to rise naturally.....just the opposite.
    How are you aerating?
    Jun 2016
    50
    Re: Lowering TA
    My mistake 12 drops of r-0009 x10 equals 120 TA. Swg to areate.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Lowering TA
    The only way TA goes up is by adding baking soda or if you are losing water from your pool and your fill water has higher TA than the pool.
    30,426
    Re: Lowering TA
    bisobx
    Jun 2016
    50
    Re: Lowering TA
    Not using nothing to areate just Swg. I have the TF 100 test kit
